Dr Phil’s copper 914 restoration thread- paint and body work on deck- getting fenders fixed and car repainted! New thread to document process, Update:- some finishing touches - constant , never done LOL |
DRPHIL914 |
Oct 28 2017, 11:47 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
after 8 years of ownership, and 2 years of rust repair and other such stuff, i am fuinally getting ready to take it to get the fenders repaired the reat of the way and the crappy respray sanded off and car repainted.
i wantes to start a new thread apart from the failed entry into the first rebuild contest. with the help of BillH1963 and a friend of his (Mike) i hope to have this done in 2 months! i am pulling this motor and transmission today. stripping car down this week and next week taking bare car with windows out, interior out, up to Mikes shop up near Columbia SC. They will be sanding it down by hand to the original primer and fixing and missed rust etc not repaired last year- as previously documented the floor pan rust jack points longs and pedal area were all repaired by Chis and Ed at Tangerine Racing in 2016. they also repaire the fender lips that were bent and damaged and massaged the rear fenders out to get room for the 7" fuchs. Now those will be smoothed out the rest of the way. and a proper match of L99k copper metallic ( goimg with the PPG - thanks for advice on this from Bill Dunster! will document this for fun and future reference- car is original matching numbers 2.0 with appearance group car- but i decided this week since i have 5 lug etc im goimg to back date the bumpers- none of this ruins originality as far as it cant be undone- i thint it will look better too so here we go!!! Attached thumbnail(s) |
DRPHIL914 |
Mar 19 2018, 09:17 AM
got a bit more done with motor tin over the weekend, ready to do push rod tube seals and then get all the tin back on- but before I do that I might paint the transmission- have not decided on chrome shop for bumpers yet,
made short list of stuff I need and stuff I want getting ready for assembly - new outer rockers, still need to get those ordred - sent my throttle body for rehab , - trim bits, - more of a want than need- interior rear targa bar pad from 914rubber, side pieces, and all the aluminum trim parts for targa and window - - will order SS fuel lines soon, , I pulled some pictures from an old thread fo the floor pan and jack point rust repair I will repost here soon, the work done by Tangerine was significant . Not the best pictures but good for documentation. - every day I wake up thinking of things to source and do , its neverending! |
Mblizzard |
Mar 19 2018, 09:54 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
got a bit more done with motor tin over the weekend, ready to do push rod tube seals and then get all the tin back on- but before I do that I might paint the transmission- have not decided on chrome shop for bumpers yet, made short list of stuff I need and stuff I want getting ready for assembly - new outer rockers, still need to get those ordred - sent my throttle body for rehab , - trim bits, - more of a want than need- interior rear targa bar pad from 914rubber, side pieces, and all the aluminum trim parts for targa and window - - will order SS fuel lines soon, , I pulled some pictures from an old thread fo the floor pan and jack point rust repair I will repost here soon, the work done by Tangerine was significant . Not the best pictures but good for documentation. - every day I wake up thinking of things to source and do , its neverending! What the issue on your TB? I have one with new sensor board already installed. |
DRPHIL914 |
Mar 19 2018, 12:03 PM
got a bit more done with motor tin over the weekend, ready to do push rod tube seals and then get all the tin back on- but before I do that I might paint the transmission- have not decided on chrome shop for bumpers yet, made short list of stuff I need and stuff I want getting ready for assembly - new outer rockers, still need to get those ordred - sent my throttle body for rehab , - trim bits, - more of a want than need- interior rear targa bar pad from 914rubber, side pieces, and all the aluminum trim parts for targa and window - - will order SS fuel lines soon, , I pulled some pictures from an old thread fo the floor pan and jack point rust repair I will repost here soon, the work done by Tangerine was significant . Not the best pictures but good for documentation. - every day I wake up thinking of things to source and do , its neverending! What the issue on your TB? I have one with new sensor board already installed. nothing horrible, its 45 years old, a bit sticky on full return, and at first opening, I did clean it but the butterfly valve gets wear as does the shaft, I just decided that it would be nice to have one that was like or better than new to put back on car - I was getting a weird occasional buck that I could never nail down for sure. might have to do with the hotspark module, or TPS but the TPS has zero wear was an NOS one I picked up and installed. It doesn't do it on full hard acceleration , like it used to when I had a worn bad TPS circuit board. either way I guess its another think to try and eliminate- it will be interesting to see if that occurs with the 123ignition distributor vs the stock one- I wont know for probably 6 weeks. oh, also trying to decide if I should repaint the gas tank while its out- wish I had a powder coater in the area close I would love to have that done. Hold on to that t.b. you never know if you will want to use that , - what you need is a car that you can drive and one that is a project.. |
Lo-Fi Version | Time is now: 23rd April 2024 - 02:23 PM |
