Something I’m Working On, MS Idle Air Valve adapter |
McMark |
Nov 2 2017, 01:57 PM
If you follow me on Instagram, you’ve seen that I’m working on a few new parts for my fuel injection setup. This one has particularly broad appeal. It a small idle air valve from a Kia that’s intended to mount onto the manifold. But I modeled up an adapter in Fusion360 to accept hose and clamp. I had this part SLS printed in Nylon from Xometry.com. It was a perfect fit/match and I’m pretty excited to see how this works. Not only is it a valve that can be controlled by mega/microsquirt but conceivably a small circuit could be designed to make this work autonomously for D-Jet and L-Jet cars in place of the AAR.
Attached thumbnail(s) Attached image(s) |
VaccaRabite |
Jul 29 2018, 08:37 PM
En Garde! Group: Admin Posts: 13,437 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Is there a standard 3 pin wire diagram for this? I've been googling and can't find the pin out.
I found a generic IAC pinout (for Volvos) that said: Pin 1 - to ECU Pin 2 - Power Pin 3 - ground is this correct? Also, I just read something you sent me about needing a resistor on the ground. How much resistance is needed? I assume I want it to ground to the main ground spot on the engine case to prevent ground loops at the ECU. Zach |
Lo-Fi Version | Time is now: 5th May 2024 - 03:00 PM |
