Shifter Ball Socket Play?, Shifter Linkage |
Movin6 |
Nov 2 2017, 04:27 PM
Member Group: Members Posts: 76 Joined: 27-July 09 From: New England Member No.: 10,615 Region Association: North East States |
I recently replaced all bushing from the firewall back, and patiently adjusted the pinch bolt at the shifter. All gears are there now. Small issue with fourth - Once I let go of the lever it 'jumps' to the left. Fifth engages ok. There is a lot of play in the ball cup. Normal or a result of nearly 50 years of ignoring the lube?
porschetub |
Nov 2 2017, 05:18 PM
I recently replaced all bushing from the firewall back, and patiently adjusted the pinch bolt at the shifter. All gears are there now. Small issue with fourth - Once I let go of the lever it 'jumps' to the left. Fifth engages ok. There is a lot of play in the ball cup. Normal or a result of nearly 50 years of ignoring the lube? Do you mean jumping out of 4th ?,I presume you have a tailshaft box ? have personally had no experience with them but I can say you need to replace EVERY part ,any piece left out is the weak link in the system. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:54 PM |
