Using chalk to determine tire pressure |
ChrisReale |
Jul 7 2003, 12:20 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
On some tires, there is a triangle on the side wall by the tread that you can use to determine how much roll the tire is experiencing. How do you use chalk to mark the triangle to determine roll? I am curious also about Victoracer tire pressures. I started out at 30psi, but determined the car handles better at 26 or 27 psi. This seems a little low to me. Any comments?
VegasRacer |
Jul 7 2003, 04:48 AM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Just put a 3" line across the tread and up the sidewall. I use white shoe polish. After a run session you can see how much roll you were getting by where the line is rubbed off. Aboooooout ....... there is perfect. Judge your tire pressures by what they are at the end of a session. 26 - 27 is not to low to start. I put 2 less in the front outside tire. Maybe 1 less in the outside rear (depending on the track). Mine feels good when I come in with hot tires at 30 - 31. If it gets much higher the Kumhos feel slippery. 30 would be an OK start if you are just autocrossing since the tires will never get a chance to heat up. Play around with it. What ever feels good (and produces lower lap times) is the right number. You optimum start pressure may change depending on the ambient temperature and the track surface.
You can get better information if you have a pyrometer. (I don't have one) I see all the fast/expensive racers do. They take inside/center/outside readings on each tire. I don't know how they interpret the data. If somebody else post a reply, we can both learn something. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:00 PM |
