6 Guys Show Me Your Breathers, Looking For Ideas |
Lucky9146 |
Nov 9 2017, 01:11 AM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,607 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
In Sept there was a thread called "Crankcase Breathers" but it seemed geared toward 4 cyl and more stock set ups through valve covers.
Forrestkhaag showed me his set up at 914 Fun Day in Temecula but other than that I have seen little for a 6. I know some kind of small tank and filter is needed. Anybody use an EMPI alum box? Suggestions for good mounting spots near the 6 tank oil filler? Pictures much appreciated! Thanks (IMG:style_emoticons/default/white914.jpg) |
rgalla9146 |
Nov 9 2017, 06:23 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
In Sept there was a thread called "Crankcase Breathers" but it seemed geared toward 4 cyl and more stock set ups through valve covers. Forrestkhaag showed me his set up at 914 Fun Day in Temecula but other than that I have seen little for a 6. I know some kind of small tank and filter is needed. Anybody use an EMPI alum box? Suggestions for good mounting spots near the 6 tank oil filler? Pictures much appreciated! Thanks (IMG:style_emoticons/default/white914.jpg) Plastic pop bottle. Weighs nothing, no cutting, no drilling, easily reversed, practically invisible, nice fit into stock breather hose. Plus you can actually see residue if blow-by is increasing. Not visible in the photo are slits along the top to allow breathing. Yes, I've fixed the fuel line snap and removed the rag. Attached thumbnail(s) |
wndsrfr |
Nov 9 2017, 06:57 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
In Sept there was a thread called "Crankcase Breathers" but it seemed geared toward 4 cyl and more stock set ups through valve covers. Forrestkhaag showed me his set up at 914 Fun Day in Temecula but other than that I have seen little for a 6. I know some kind of small tank and filter is needed. Anybody use an EMPI alum box? Suggestions for good mounting spots near the 6 tank oil filler? Pictures much appreciated! Thanks (IMG:style_emoticons/default/white914.jpg) Here ya go... |
pcar916 |
Nov 9 2017, 09:29 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Here's mine in the 6 on the firewall right behind the driver's seat. It's a modified hiking water bottle in powder-coated aluminum... for the budget conscious builder. Hardly ever gets any oil in it. K&N breather filter.
Ron |
Lucky9146 |
Nov 9 2017, 10:26 AM
Plastic pop bottle. Weighs nothing, no cutting, no drilling, easily reversed, practically invisible, nice fit into stock breather hose. Plus you can actually see residue if blow-by is increasing. Not visible in the photo are slits along the top to allow breathing. Yes, I've fixed the fuel line snap and removed the rag. Love the simplicity thanks for the idea. It was great to look in this morning and find 3 responses with yours being the first! (IMG:style_emoticons/default/white914.jpg) |
Lucky9146 |
Nov 9 2017, 10:30 AM
Looks really professional and thanks for your idea and pictures. What looks to be a sight gage is pretty cool looking. Can you please tell me where the two hoses trail off to in the trunk? Thanks again (IMG:style_emoticons/default/white914.jpg) |
PanelBilly |
Nov 9 2017, 10:38 AM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Lucky9146 |
Nov 9 2017, 10:39 AM
Here's mine in the 6 on the firewall right behind the driver's seat. It's a modified hiking water bottle in powder-coated aluminum... for the budget conscious builder. Hardly ever gets any oil in it. K&N breather filter. Ron Very creative and nice looking, the German clamp is a great touch! Like "for the budget conscious builder" because at this point it would be cool not to spend much on this tid bit. Great ideas so far! Thanks (IMG:style_emoticons/default/white914.jpg) |
Lucky9146 |
Nov 9 2017, 11:28 AM
Looks really good! Does it come complete just like that with filter and drain? I'll check it out. Thanks for the idea and the picture! (IMG:style_emoticons/default/white914.jpg) |
GeorgeRud |
Nov 9 2017, 06:11 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Has anyone tried venting the tank to the top of the Weathershield air cleaner assembly? I assumed that may be the purpose of the drilled hole on the side of the upper assembly.
Larmo63 |
Nov 9 2017, 06:35 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
914 Ranch |
Nov 9 2017, 06:58 PM
Team Sharp where the 914 grow wings Group: Members Posts: 1,411 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
wndsrfr |
Nov 9 2017, 09:29 PM
Looks really professional and thanks for your idea and pictures. What looks to be a sight gage is pretty cool looking. Can you please tell me where the two hoses trail off to in the trunk? Thanks again (IMG:style_emoticons/default/white914.jpg) They just poke out the bottom to apply a bit of rust preventive to the underside of the hot trunk floor..... (IMG:style_emoticons/default/biggrin.gif) |
t collins |
Nov 9 2017, 10:21 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
PanelBilly |
Nov 9 2017, 10:29 PM
Looks really good! Does it come complete just like that with filter and drain? I'll check it out. Thanks for the idea and the picture! (IMG:style_emoticons/default/white914.jpg) I don’t remember if it was a set or a “buy this too” deal. Came with a valve for draining |
mb911 |
Nov 11 2017, 04:45 PM
914 Guru Group: Members Posts: 6,827 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Here is what I made for my last six..
Attached image(s) |
Lucky9146 |
Nov 11 2017, 09:26 PM
Here is what I made for my last six.. Thanks and I really like the plexiglass over the carbs! (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/white914.jpg) |
Lo-Fi Version | Time is now: 6th May 2024 - 01:22 PM |
