Pliers and screw driver names |
cal44 |
Nov 9 2017, 03:27 PM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
Can you'all give me a heads up on the name (manufacturer) on the pliers, 10/13 open end wrench and screw driver for the tool kit 1974.
Thank you |
maf914 |
Nov 14 2017, 08:17 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
What is the function of the U-shaped bent wire tool with hooked ends located next to the tow-eye in the above photo? (IMG:style_emoticons/default/idea.gif)
bdstone914 |
Nov 14 2017, 08:27 AM
bdstone914 Group: Members Posts: 4,507 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What is the function of the U-shaped bent wire tool with hooked ends located next to the tow-eye in the above photo? (IMG:style_emoticons/default/idea.gif) Early hub cap puller. There are two holes in the edge of the hub cap to use with that tool. The puller look longer than most I have seen. |
Lo-Fi Version | Time is now: 18th April 2024 - 05:41 PM |
