Side shift linkage options? |
rcarson25 |
Nov 9 2017, 06:15 PM
Member Group: Members Posts: 62 Joined: 15-May 17 From: TN Member No.: 21,103 Region Association: South East States |
Title pretty much says it, but I am looking at options for shifter linkage setups for a 914 side shift transmission. I have a trans and no linkage, so I am looking at best/cheapest options for converting the linkage over. Thanks in advance.
Steve |
Nov 9 2017, 06:57 PM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Stock (cheapest) post WTB in classifieds or (best) http://www.tangerineracing.com/transmission.htm |
ottox914 |
Nov 9 2017, 07:12 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
+1 for tangerine. Have that in my car and it's great. Way better than oem, but $$$.
And worth it. |
rcarson25 |
Nov 9 2017, 07:34 PM
+1 for tangerine. Have that in my car and it's great. Way better than oem, but $$$. And worth it. I know that tangerine is speedy, wouldn’t I still need to get the interior shifter rod to work with that setup? And possibly a shifter as well? I did post a wtb thread as well. |
rcarson25 |
Nov 9 2017, 07:35 PM
(IMG:style_emoticons/default/welcome.png) Stock (cheapest) post WTB in classifieds or (best) http://www.tangerineracing.com/transmission.htm Thanks for he welcome by the way. |
Steve |
Nov 9 2017, 07:44 PM
Yep, you need the interior Parts to. The Tangarene stuff is only from the firewall back.
So you still need: -side shifter shifter 73-76 -side shifter interior shift rod 73-76 |
Nov 9 2017, 07:47 PM
914-6 GT in waiting Group: Members Posts: 19,216 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/welcome.png) Stock (cheapest) post WTB in classifieds or (best) http://www.tangerineracing.com/transmission.htm (IMG:style_emoticons/default/agree.gif) you can always start with stock and upgrade to tangerine. I prefer once and done. |
GeorgeRud |
Nov 9 2017, 07:48 PM
I’d check with some of the recyclers to see if someone can’t fix you up with the complete system. I’ve had good luck with Garold Shaffer in Portage, IN and also with Brad Mayeur at 914Ltd in E. Peoria, Il.
rcarson25 |
Nov 10 2017, 06:05 PM
(IMG:style_emoticons/default/welcome.png) Stock (cheapest) post WTB in classifieds or (best) http://www.tangerineracing.com/transmission.htm (IMG:style_emoticons/default/agree.gif) you can always start with stock and upgrade to tangerine. I prefer once and done. Does this kit really make that much difference? $500 seems spendy for a metal rod and a couple joints. Welcome to the world of Porsche haha. |
Nov 10 2017, 06:12 PM
(IMG:style_emoticons/default/welcome.png) Stock (cheapest) post WTB in classifieds or (best) http://www.tangerineracing.com/transmission.htm (IMG:style_emoticons/default/agree.gif) you can always start with stock and upgrade to tangerine. I prefer once and done. Does this kit really make that much difference? $500 seems spendy for a metal rod and a couple joints. Welcome to the world of Porsche haha. It’s not a Porsche tax. It’s a limited production, custom solution to improve the precision of the shift assembly. Chris also has a precision shift coupler $200, firewall bushing $50 and many people install a jwest - rennshifter $550 to improve shifting. You asked for two different things; cheapest - stock Best- stock combined with aftermarket mods. |
Nov 10 2017, 06:33 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If you can put together a u-joint and a couple of rods and have it work better than stock, maybe you should make it yourself...
I know I can't do a better job, so if I do decide to upgrade from the stock linkage I'm pretty sure I'll be calling Chris. Another option is a cable shifter. Evidently Boxster cables are about the right length, but you do have to run the cables and mount the gear shift lever and hook the cables up to the trans appropriately... --DD |
cary |
Nov 10 2017, 10:42 PM
PM, bdstone914. See if he has any complete setups left.
Ditto on the Tangerine firewall bushing. We have 3 incoming for projects here at MiddleMotors. Then add the brass console bushing from Brain at GPR. https://www.ebay.com/itm/-/370858106656 I have 6 incoming here at MiddleMotors. Don't forget motor mount bar .................. |
Larmo63 |
Nov 10 2017, 10:47 PM
I have a motor mount bar, rear stock shaft, and bronze bushing available.
ChrisFoley |
Nov 11 2017, 11:09 AM
I am Tangerine Racing Group: Members Posts: 7,907 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
We have 3 incoming for projects here at MiddleMotors. Three? I have an order for two in transit to Oregon right now. Last two from stock actually. I'll have to work on another batch of firewall bushing housings as soon as I finish a run of oil pressure relief housings in the lathe. |
914forme |
Nov 11 2017, 12:12 PM
(IMG:style_emoticons/default/lol-2.gif) Chris thats the way it goes, you build a quality beast, then some of us purchase them, and start spreading the word, and then for your success you are granted, well more work.
(IMG:style_emoticons/default/aktion035.gif) Your welcome (IMG:style_emoticons/default/av-943.gif) |
914forme |
Nov 11 2017, 12:14 PM
Is Chris' stuff worth it, yes. Is Rennshifter or Wevo worth it. Yes. All combined worth every penny, if you don't feel like being a fabricator.
Even I who love to fabricate still finds it is less time for the $$$ spent in purchasing quality items to make the process faster. Oh and (IMG:style_emoticons/default/welcome.png) |
cary |
Nov 11 2017, 12:34 PM
We have 3 incoming for projects here at MiddleMotors. Three? I have an order for two in transit to Oregon right now. Last two from stock actually. I'll have to work on another batch of firewall bushing housings as soon as I finish a run of oil pressure relief housings in the lathe. Two for Mike. Doug will be ordering one shortly, I thought it was ordered yesterday. One of Mike's goes in next week. The other is a spare. We can use that one in Doug's car if need be. Let's plan on three from over here in that next batch. One for Doug. And I'll put two on the shelf here at MiddleMotors. Thanks Chris, great product. |
ChrisFoley |
Nov 11 2017, 01:06 PM
(IMG:style_emoticons/default/lol-2.gif) Chris thats the way it goes, you build a quality beast, then some of us purchase them, and start spreading the word, and then for your success you are granted, well more work. (IMG:style_emoticons/default/aktion035.gif) Your welcome (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/biggrin.gif) I don't have too much work. But when my full time welder/fabricator left a year ago I decided I could do it all myself, and I got way behind as I slowly came up to speed. At least now I can always vouch for the quality of the results. |
rcarson25 |
Nov 11 2017, 08:14 PM
Is Chris' stuff worth it, yes. Is Rennshifter or Wevo worth it. Yes. All combined worth every penny, if you don't feel like being a fabricator. Even I who love to fabricate still finds it is less time for the $$$ spent in purchasing quality items to make the process faster. Oh and (IMG:style_emoticons/default/welcome.png) Thanks, this is exactly what I was looking for. I have built quite a few cars and I can fab a lot of stuff. I have found that expensive isn't always the best solution, but sometimes it does. I don't mind paying for quality, which is sounds like Tangerine's products are. I am new to the 914 word so I don't know the quality from the overpriced yet. Sounds to me that if I decide to upgrade, Tangerine is the place to call! |
saigon71 |
Nov 12 2017, 07:44 AM
Senior Member Group: Members Posts: 1,994 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'd start with a stock setup with new bushings all around. It's really not a bad setup.
If you aren't satisfied with it, you can't go wrong with the Tangerine upgrade. |
Lo-Fi Version | Time is now: 18th April 2024 - 01:05 PM |
