Mortality rate of Pertronix 2, ECU, and coil..., Plugs have weak spark, gas getting in cly., no pop whatsoever |
second wind |
Nov 9 2017, 11:03 PM
Senior Member Group: Members Posts: 847 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey guys,
'73 2.0 FI blew a spark plug out...fixed it and it ran so-so...then it didn't run at all...then it ran perfect for 20 minutes...then next day ran for a minute and died. Plugs have weak spark but couldn't get a pop out of any cylinders for two hours....still dead....have checked a lot of wires and logically it should at least fire a bit but absolutely nothing. Maybe spark too weak to fire under compression? Or some component dead I can't figure out? Even with starting fluid not a single pop. Your thoughts? Thank you. gg |
Nov 9 2017, 11:51 PM
914 Idiot Group: Members Posts: 14,974 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Needs fuel, air, and spark.
Sounds like the spark is weak. Not great. Possibly try disconnecting all the extra stuff from the coil (tach signal wire, any extra crap that got plugged in) and see if that improves it. Check for fuel. You can put the injectors into jars and look while the starter is cranking. You can also look at the spray pattern to make sure it is vaguely cone-shaped. Check for air--or rather, compression. All four cylinders. If you have those, the only variables are when the sparks happen (timing), and how much fuel is going in (mixture). --DD |
second wind |
Nov 10 2017, 12:22 AM
Needs fuel, air, and spark. Sounds like the spark is weak. Not great. Possibly try disconnecting all the extra stuff from the coil (tach signal wire, any extra crap that got plugged in) and see if that improves it. Check for fuel. You can put the injectors into jars and look while the starter is cranking. You can also look at the spray pattern to make sure it is vaguely cone-shaped. Check for air--or rather, compression. All four cylinders. If you have those, the only variables are when the sparks happen (timing), and how much fuel is going in (mixture). --DD Thank you DD...I did pull injectors and they squirt....it is a real puzzle unless there is no spark in the cylinder....is that possible? Driving me nuts....car ran beautiful but quit in driveway....something changed....but what?? gg |
somd914 |
Nov 10 2017, 06:06 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
Do you smell gas when trying to start? If you pull a plug after attempting to start is it soaked with gas? As for weak spark, assume this is based on pulling a plug and cranking with the plug grounded against the engine case or other good ground?
If she is flooding, I'd take a look at your CHT sensor. A bad sensor or broken lead/harness wire on the CHT can cause flooding and no start, even to the point of showing no willingness to kick/pop. |
second wind |
Nov 10 2017, 12:38 PM
Do you smell gas when trying to start? If you pull a plug after attempting to start is it soaked with gas? As for weak spark, assume this is based on pulling a plug and cranking with the plug grounded against the engine case or other good ground? If she is flooding, I'd take a look at your CHT sensor. A bad sensor or broken lead/harness wire on the CHT can cause flooding and no start, even to the point of showing no willingness to kick/pop. Wow Somd914....you are describing it exactly as it is. I am judging the spark with a spark plug pushed against a part of the engine....very weak spark....lots of gas smell....while repairing the blown out spark plug I nudged and pulled on all the wires in the area. I will get back in there and double check all of the wires. How do you test the CHT? Thank you. gg |
Rand |
Nov 11 2017, 12:05 AM
Did you nudge them to the left, or right? How's the barn coming? Did you sell off the other cars?
Have you checked out the Fiat x19 forums? They are great fodder. Seriously, you could win there. -oi812 |
somd914 |
Nov 11 2017, 06:48 AM
Do you smell gas when trying to start? If you pull a plug after attempting to start is it soaked with gas? As for weak spark, assume this is based on pulling a plug and cranking with the plug grounded against the engine case or other good ground? If she is flooding, I'd take a look at your CHT sensor. A bad sensor or broken lead/harness wire on the CHT can cause flooding and no start, even to the point of showing no willingness to kick/pop. Wow Somd914....you are describing it exactly as it is. I am judging the spark with a spark plug pushed against a part of the engine....very weak spark....lots of gas smell....while repairing the blown out spark plug I nudged and pulled on all the wires in the area. I will get back in there and double check all of the wires. How do you test the CHT? Thank you. gg It's been a while since I messed with D-Jet, went carbs several years ago. I'm looking for the resistance specs and D-Jet harness pin out, but you'll need a multimeter to read the resistance of the sensor. Its resistance changes with temperature to change fuel enrichment. With high resistance or an open such as a broken lead wire, the mixture goes very rich and the engine won't run. First step is to disconnect the CHT from the D-Jet harness and test the resistance at the CHT connector. If out of tolerance, then replace the sensor. If it's good, reconnect the CHT connector to the harness, then you will need to pull the harness cable at the engine control unit and test resistance from the control unit connector. In my case, I had a broken wire in the harness a few inches from the CHT connector. It made intermittent contact, so it would run occasionally then die, or it would crank with no signs of firing off, just flooding. Sorry, I'll see if I can track down resistance specs and control unit connector pin outs, or perhaps someone else will chime in... |
76-914 |
Nov 11 2017, 10:50 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Check your distributor cap center (coil contact) pin. It's spring loaded and should push in at least 1/4". If it's worn to the end limit it will make a poor "on again, off again" contact. (IMG:style_emoticons/default/beerchug.gif)
914_teener |
Nov 11 2017, 11:38 AM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Do you smell gas when trying to start? If you pull a plug after attempting to start is it soaked with gas? As for weak spark, assume this is based on pulling a plug and cranking with the plug grounded against the engine case or other good ground? If she is flooding, I'd take a look at your CHT sensor. A bad sensor or broken lead/harness wire on the CHT can cause flooding and no start, even to the point of showing no willingness to kick/pop. Wow Somd914....you are describing it exactly as it is. I am judging the spark with a spark plug pushed against a part of the engine....very weak spark....lots of gas smell....while repairing the blown out spark plug I nudged and pulled on all the wires in the area. I will get back in there and double check all of the wires. How do you test the CHT? Thank you. gg It's been a while since I messed with D-Jet, went carbs several years ago. I'm looking for the resistance specs and D-Jet harness pin out, but you'll need a multimeter to read the resistance of the sensor. Its resistance changes with temperature to change fuel enrichment. With high resistance or an open such as a broken lead wire, the mixture goes very rich and the engine won't run. First step is to disconnect the CHT from the D-Jet harness and test the resistance at the CHT connector. If out of tolerance, then replace the sensor. If it's good, reconnect the CHT connector to the harness, then you will need to pull the harness cable at the engine control unit and test resistance from the control unit connector. In my case, I had a broken wire in the harness a few inches from the CHT connector. It made intermittent contact, so it would run occasionally then die, or it would crank with no signs of firing off, just flooding. Sorry, I'll see if I can track down resistance specs and control unit connector pin outs, or perhaps someone else will chime in... Broken MPS diaphram will flood the engine like it is WOT. |
Rand |
Nov 11 2017, 11:39 AM
If this post is for real...
Check the braided ground wire between the advance plates in the distributor. It's not uncommon for one end to come loose. If that connection is bad, it causes weak spark. Sort of a needle in a hay stack, so good to know. |
second wind |
Nov 11 2017, 02:38 PM
Yes this post is for real. I have a new distributor cap on there and will be checking the braided ground wire as suggested. Will be tracing the CHT sensor lead wire as well. Mikey said he has new CHT sensors but I wonder if the 012 vs.017 part number discrepancy will be an issue? Thank you for the PM Mark and all other responders.
gg |
Rand |
Nov 11 2017, 02:57 PM
Trying after all the OU812, you understand.
76-914 |
Nov 11 2017, 04:37 PM
Rand |
Nov 11 2017, 05:01 PM
Sigh. Sorry Greg. Kent's word is good enough for me. It's just that ou812 left a bad taste in our mouths, changed his screen name to something like second wind... The remains of a polluter. I just don't have tolerance for trolls, but letting it go.
Seriously, check the ground wire between the dizzy plates. Happened to me in a parking lot. Cranked, backfired, wouldn't run. Checked spark, it was weak yellow. Found the wire broke loose on one of the plates. Still had *some* spark but it was weak. Swapped in a spare dizzy and it fired right up. YMMV but just something on the table. (IMG:style_emoticons/default/beerchug.gif) |
second wind |
Nov 11 2017, 07:18 PM
Sigh. Sorry Greg. Kent's word is good enough for me. It's just that ou812 left a bad taste in our mouths, changed his screen name to something like second wind... The remains of a polluter. I just don't have tolerance for trolls, but letting it go. Seriously, check the ground wire between the dizzy plates. Happened to me in a parking lot. Cranked, backfired, wouldn't run. Checked spark, it was weak yellow. Found the wire broke loose on one of the plates. Still had *some* spark but it was weak. Swapped in a spare dizzy and it fired right up. YMMV but just something on the table. (IMG:style_emoticons/default/beerchug.gif) Oh...Ok....I get it...you're treating me like Emmett Till but just now realize I'm some other guy....I will let it go if you can solve the puzzle..... Regards, gg |
second wind |
Nov 11 2017, 07:46 PM
Sigh. Sorry Greg. Kent's word is good enough for me. It's just that ou812 left a bad taste in our mouths, changed his screen name to something like second wind... The remains of a polluter. I just don't have tolerance for trolls, but letting it go. Seriously, check the ground wire between the dizzy plates. Happened to me in a parking lot. Cranked, backfired, wouldn't run. Checked spark, it was weak yellow. Found the wire broke loose on one of the plates. Still had *some* spark but it was weak. Swapped in a spare dizzy and it fired right up. YMMV but just something on the table. (IMG:style_emoticons/default/beerchug.gif) Yeah Rand.....thanks for the help. Just to get it out of my system, I suspect the only bad taste in your mouth is from Kent's dick. Fuck you both!! Sincerely, gg |
Nov 11 2017, 08:54 PM
Wow, sounds like someone needs a time out...
--DD |
second wind |
Nov 12 2017, 12:57 PM
Do you smell gas when trying to start? If you pull a plug after attempting to start is it soaked with gas? As for weak spark, assume this is based on pulling a plug and cranking with the plug grounded against the engine case or other good ground? If she is flooding, I'd take a look at your CHT sensor. A bad sensor or broken lead/harness wire on the CHT can cause flooding and no start, even to the point of showing no willingness to kick/pop. Wow Somd914....you are describing it exactly as it is. I am judging the spark with a spark plug pushed against a part of the engine....very weak spark....lots of gas smell....while repairing the blown out spark plug I nudged and pulled on all the wires in the area. I will get back in there and double check all of the wires. How do you test the CHT? Thank you. gg It's been a while since I messed with D-Jet, went carbs several years ago. I'm looking for the resistance specs and D-Jet harness pin out, but you'll need a multimeter to read the resistance of the sensor. Its resistance changes with temperature to change fuel enrichment. With high resistance or an open such as a broken lead wire, the mixture goes very rich and the engine won't run. First step is to disconnect the CHT from the D-Jet harness and test the resistance at the CHT connector. If out of tolerance, then replace the sensor. If it's good, reconnect the CHT connector to the harness, then you will need to pull the harness cable at the engine control unit and test resistance from the control unit connector. In my case, I had a broken wire in the harness a few inches from the CHT connector. It made intermittent contact, so it would run occasionally then die, or it would crank with no signs of firing off, just flooding. Sorry, I'll see if I can track down resistance specs and control unit connector pin outs, or perhaps someone else will chime in... Broken MPS diaphram will flood the engine like it is WOT. MPS passed pressure holding test....thank you. gg |
76-914 |
Nov 12 2017, 01:18 PM
Sigh. Sorry Greg. Kent's word is good enough for me. It's just that ou812 left a bad taste in our mouths, changed his screen name to something like second wind... The remains of a polluter. I just don't have tolerance for trolls, but letting it go. Seriously, check the ground wire between the dizzy plates. Happened to me in a parking lot. Cranked, backfired, wouldn't run. Checked spark, it was weak yellow. Found the wire broke loose on one of the plates. Still had *some* spark but it was weak. Swapped in a spare dizzy and it fired right up. YMMV but just something on the table. (IMG:style_emoticons/default/beerchug.gif) Yeah Rand.....thanks for the help. Just to get it out of my system, I suspect the only bad taste in your mouth is from Kent's dick. Fuck you both!! Sincerely, gg Your a EDIT. I was standing up for you. Are you the guy with the light blue 914 that was at the last WCR? |
second wind |
Nov 12 2017, 02:55 PM
Sigh. Sorry Greg. Kent's word is good enough for me. It's just that ou812 left a bad taste in our mouths, changed his screen name to something like second wind... The remains of a polluter. I just don't have tolerance for trolls, but letting it go. Seriously, check the ground wire between the dizzy plates. Happened to me in a parking lot. Cranked, backfired, wouldn't run. Checked spark, it was weak yellow. Found the wire broke loose on one of the plates. Still had *some* spark but it was weak. Swapped in a spare dizzy and it fired right up. YMMV but just something on the table. (IMG:style_emoticons/default/beerchug.gif) Yeah Rand.....thanks for the help. Just to get it out of my system, I suspect the only bad taste in your mouth is from Kent's dick. Fuck you both!! Sincerely, gg Your a EDIT. I was standing up for you. Are you the guy with the light blue 914 that was at the last WCR? Wow....I know you stood up for me...thank you....no anger aimed at you...those two other guys were accusing me of being some other guy...how did I offend you? I whole heartedly apologize for upsetting you... gg |
Lo-Fi Version | Time is now: 29th March 2024 - 04:25 AM |
