Cutting Out Section of Forward Firewall, Moving Back Fuel Cell to make Room for Radiator |
motorvated |
Nov 10 2017, 05:21 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Might be moving forward with V8 conversion of the '72 Chalon-bodied race car and was hoping not to have to lay out $3K for a custom fit fuel cell that goes in where the stock tank originally resided. I currently have a 12 gal rectangular fuel cell that takes up most of the room in the frunk, and doesn't leave enough room for a radiator. I was thinking of raising the height of the fuel cell so it won't interfere with my front sway bar and cutting an opening in the forward "firewall" to allow me to slide the fuel cell rearward to butt up against the rear true firewall. I haven't seen anyone else do this, so I'm wondering if it can't be done for structural or other reasons. Any insights on this?
Current placement of fuel cell. |
euro911 |
Nov 14 2017, 01:21 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Engman used to make block-off plates for the fresh-air vent openings. ... not sure if Mad Dog is making them now?
stownsen914 |
Nov 14 2017, 11:05 AM
It should be OK to cut through the metal in the bulkhead between the shock towers. As mentioned elsewhere, you might consider reinforcing that area if you wind up cutting a lot of it out since it's important for maintaining front suspension geometry.
I put the fuel cell for my 914 in the forward portion of the passenger footwell. It leaves lots of room up front for oil cooler ducting, and keeps the weight from fuel low and on the right side of the car to offset driver weight. I guess one could argue that corner weights will change as the tank empties, but car balance will change as the tank empties no matter where you put it. I'm not a fan of putting the fuel tank up high if it can be avoided, since a full tank is a lot of weight. Scott |
Lo-Fi Version | Time is now: 18th May 2024 - 05:03 AM |
