Cutting Out Section of Forward Firewall, Moving Back Fuel Cell to make Room for Radiator |
motorvated |
Nov 10 2017, 05:21 PM
Member Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Might be moving forward with V8 conversion of the '72 Chalon-bodied race car and was hoping not to have to lay out $3K for a custom fit fuel cell that goes in where the stock tank originally resided. I currently have a 12 gal rectangular fuel cell that takes up most of the room in the frunk, and doesn't leave enough room for a radiator. I was thinking of raising the height of the fuel cell so it won't interfere with my front sway bar and cutting an opening in the forward "firewall" to allow me to slide the fuel cell rearward to butt up against the rear true firewall. I haven't seen anyone else do this, so I'm wondering if it can't be done for structural or other reasons. Any insights on this?
Current placement of fuel cell. |
mlindner |
Nov 19 2017, 12:49 PM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Motorvated, how about just a new tank/cell that is more vertical and keep the wall intact and still leaves room for oil cooler ducting. Best, Mark
motorvated |
Nov 19 2017, 09:57 PM
Motorvated, how about just a new tank/cell that is more vertical and keep the wall intact and still leaves room for oil cooler ducting. Best, Mark I need quite a bit of space for engine coolant radiator with fans and inlet ducting, as I'm installing a 0.030 over 215 Buick V8 motor. More space than needed for just a forward oil cooler. I'd rather not cut the forward metal bulkhead between the strut towers. I have since located and purchased a used cell with bladder that fits in the stock tank location from another world member, just waiting for it to be shipped. I checked SCCA rules, and they specifically say that there is no time limit on fuel cells, so a good used one should be OK. |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:26 AM |
