E-Stopp emergency brake install, Advice on best unit and install |
Gmanscott55 |
Nov 11 2017, 05:19 PM
Member Group: Members Posts: 182 Joined: 3-February 16 From: Sunset Beach,Ca Member No.: 19,630 Region Association: Southern California |
I currently do not have an e brake installed. Previous owner did not put in possibly due to race seats in front? Any advice on remote e brake kits such as e-stopp or others? Any restrictions or best place to install? Thanks in advance for your help.
Mike1981 |
Nov 11 2017, 05:55 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
I am in need of an e-brake as well
I have the cable run to the back but no brackets to attach to the rear calipers Even would consider a aux system thanks |
Nov 11 2017, 06:02 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Tangerine racing has an easy to use adaptor for adding a 911 e-brake to a 914.
Larmo63 |
Nov 11 2017, 06:09 PM
It almost seems as if there could be small disc brakes adapted to CV joints?
Steve |
Nov 11 2017, 08:41 PM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I would buy Tangerines kit. There is a thread on how to bolt the 911 shoe brake e-brake assembly to the trailing arm.
http://www.914world.com/bbs2/index.php?showtopic=4909 I am not a fan of the metal stop on the shoe brake. The factory welded a heavy plate to the trailing arm for a reason. If you just want a parking brake it’s fine, but picture your self grabbing the emergency brake at speed. The brakes shoes will rip off that metal tab if it’s welded to the thin sheet metal of the e-brake assembly. Wes (rip) helped me with mine. Here is a link to his thread. http://www.914world.com/bbs2/index.php?sho...72&hl=Brake |
Nov 11 2017, 09:05 PM
The tangerine kit welds the stop plates on the trailing arms.
porschetub |
Nov 12 2017, 01:54 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
[/quote] (IMG:style_emoticons/default/agree.gif) ask my how I know,it not only rips the stop off the backing plate the springs and shoe retainers get destroyed @ the same time. The 911 backing plate isn't heavy enough,Steve is correct 100%...you have a handbrake but not an emergency one if the conversion is done this way. I intent to re-engineer what the PO did with my setup.....peace of mind from a safety point of view also. |
Gmanscott55 |
Nov 13 2017, 07:40 PM
Thanks to all who responded... (IMG:style_emoticons/default/aktion035.gif)
Jeff Hail |
Nov 13 2017, 09:40 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
RIF
The stop is welded to the arm. Pretty stout plate. With a 1/4 inch of bead on both sides its not going to tear off. The shoes are mounted inside the rotors drum recess. On the opposite end of the stop are the adjusters. Where is it going to rotate to? Back in the days of the dinosaurs drum brake shoes were mounted to the backing plate held onto an axle housing by 4 bolts. Shoes were tethered by pins, springs and keepers to the backing plate with similar stop. Oh wait they are still like that on modern cars and trucks. Attached image(s) |
porschetub |
Nov 14 2017, 03:52 PM
Thanks Jeff that's the way I'am going....nice and solid,lots of different ways to skin this cat and mines done rather differently ,wouldn't have been my first chose the Tangerine set up makes more sense to me,having said that what the PO did a good job but didn't think it out 100%.
The rest of the brakes are top notch so having bought a project car I shouldn't complain. |
mmascari |
Nov 14 2017, 05:07 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
Tangerine racing has an easy to use adaptor for adding a 911 e-brake to a 914. I converted my rear to 5-lug with drilled hubs and now have Boxster rear calipers and of course no e-brake. I would like to install an e-brake but not sure what parts to buy. Does anyone have the list of parts needed other than the tangerine kit? I assume the stock early 911 e-brake parts? Do you still utililze the stock 914 e-bake cables? |
Jeff Hail |
Nov 14 2017, 05:29 PM
Tangerine racing has an easy to use adaptor for adding a 911 e-brake to a 914. I converted my rear to 5-lug with drilled hubs and now have Boxster rear calipers and of course no e-brake. I would like to install an e-brake but not sure what parts to buy. Does anyone have the list of parts needed other than the tangerine kit? I assume the stock early 911 e-brake parts? Do you still utililze the stock 914 e-bake cables? I bought a pair of used 912 rear parking brakes with backing plates, pads and all hardware cheap. About a third the price of used 911 parts and they are the same. Replaced springs, pins, keepers and spreaders new. I used 911 bearing retainer plates since the backing plates alone are not robust enough to keep the bearing in check under side load. You can grind your 914 ones down or use the 911 retainers to double it up. The 911 bearing retainers are late model and will need to have the holes opened up a pinch. Early retainers are NLA. Attached image(s) |
worn |
Nov 14 2017, 08:40 PM
can't remember Group: Members Posts: 3,144 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I currently do not have an e brake installed. Previous owner did not put in possibly due to race seats in front? Any advice on remote e brake kits such as e-stopp or others? Any restrictions or best place to install? Thanks in advance for your help. However way you go, read the threads and please don’t go with a 0.5ass solution. These are to keep your car from running away from you down a hill. They are to save lives when your brake lines shoot out fluid and spray like a surfacing Orca. Think of your loved one trying to hold back that ton of narp. I commend you and all for tryin to fix it! Was going back to stock not an option? |
Lo-Fi Version | Time is now: 20th April 2024 - 12:02 AM |
