Yet another head thread, Need advice |
bbrock |
Nov 11 2017, 06:37 PM
This is related to the AA/HAM head GB but I didn't want to hijack. But that offer means I need to make some decisions sooner than anticipated on my resto. The main question is whether to rework these heads or buy new? My very strong preference is to rework what I have, assuming the castings are good. They have not been cleaned so I was thinking about walnut blasting them myself so I can inspect for cracks before deciding whether to move forward on reworking. Is there any reason I should not blast them myself? Any spots that should be masked or blocked before blasting? Basically, I just want to get to a decision point on whether to rework or buy new. After reading so much about how hard it is getting to find good original castings has me a bit spooked, and if I hit a dead end on reworking, I'd like to do it while the HAM GB is still an option. I also don't know what a basic head rebuild will cost. Anyone have a ballpark estimate? I used to be able to send them out to Cali for a couple hundred bucks, but those days are gone. Here's a short version of the history my engine. It's GA 2.0L engine that I rebuilt the bottom end on in the late 80s, but the project stalled before I got to the heads. My best guess is that the engine had about 110K-120K miles on it when it was split. That's a guess because the odometer quit at about 92K shortly after I bought the car. The engine ran strong when the FI cooperated when it was pulled, so no reason to suspect any major issues. Other than a busted exhaust stud, the heads look good with no broken fins and very little carbon in the combustion chamber. So, overall, I feel these heads are a good candidate for rebuilding but would appreciate any advice or opinions. |
McMark |
Nov 28 2017, 01:34 PM
914 Freak! Group: Retired Admin Posts: 20,177 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
You should replace them all. The sodium valve can snap off (probably what happened to nditz1's engine). Dropping a valve or a seat makes a big mess and is one of the more catastrophic failures.
bbrock |
Nov 28 2017, 05:56 PM
You should replace them all. The sodium valve can snap off (probably what happened to nditz1's engine). Dropping a valve or a seat makes a big mess and is one of the more catastrophic failures. Sadly, I know this first hand. Had the #3 let go in two different engines in a VW bus I once had. Both at highways speed. Schrapnel welded into the head and knocked a hole through the case both times. Would rather avoid a repeat. |
Lo-Fi Version | Time is now: 29th March 2024 - 01:10 AM |
