Rear Wheel Bearing wobble, New rear wheel bearing has unusual play |
paintguru |
Nov 12 2017, 11:08 AM
Newbie Group: Members Posts: 13 Joined: 24-October 15 From: Southern Oregon Member No.: 19,295 Region Association: Pacific Northwest |
Has anyone experienced excessive play in a newly installed rear wheel bearing? During the restoration of my 72 I installed new bearings. The left rear has no play and the hub rotates smoothly. The right side seems to have excessive play and with the car on the lift I can wiggle the tire and wheel left and right about 1/8th of an inch. Thinking I might have damaged the bearing during install I ordered another one. Yes I bought decent quality from Pelican and not a made in china cheapie. Again I carefully pressed in the bearing feeling confident it was not damaged but once again the hub rocks while the other side doesn't. Thoughts?
McMark |
Nov 13 2017, 09:18 AM
Getting the slop to disappear requires that the stub axle be fully seated into the hub, and the hub to be fully seated against the bearing. Rust, dirt, or damage can keep things from seating fully by hand. Most of the time those factors are irrelevant against 200+ft/lbs of torque, so it's not a problem once torqued. If you really want to go the extra mile, make sure those components are clean and smooth.
I always do a little cleanup with a fine ScotchBrite pad as well as taking a dental pick to each and every groove in both sides of he spline joint. Also a thin layer of grease on all surfaces. You want to make sure this stuff will come apart again later. |
Lo-Fi Version | Time is now: 6th May 2024 - 08:25 PM |
