Rear Wheel Bearing wobble, New rear wheel bearing has unusual play |
paintguru |
Nov 12 2017, 11:08 AM
Newbie Group: Members Posts: 13 Joined: 24-October 15 From: Southern Oregon Member No.: 19,295 Region Association: Pacific Northwest |
Has anyone experienced excessive play in a newly installed rear wheel bearing? During the restoration of my 72 I installed new bearings. The left rear has no play and the hub rotates smoothly. The right side seems to have excessive play and with the car on the lift I can wiggle the tire and wheel left and right about 1/8th of an inch. Thinking I might have damaged the bearing during install I ordered another one. Yes I bought decent quality from Pelican and not a made in china cheapie. Again I carefully pressed in the bearing feeling confident it was not damaged but once again the hub rocks while the other side doesn't. Thoughts?
cary |
Nov 12 2017, 07:24 PM
1. Same thing happened on my 911 many years ago.
2. Have you put it on the ground yet ? If not, lower and torque to spec. Torque to 217 then dial it in till you line up the next cotter key slot.Then see what you have. Maybe. But I kind of doubt it. 3. Ditto on FAG |
Lo-Fi Version | Time is now: 28th March 2024 - 03:17 AM |
