SOT: 930 Tach disassembly FT! is rattling in there?, Unless your running a boosted -6 |
914forme |
Nov 12 2017, 07:58 PM
So I have a 930 Tach, and every time you rolled it around it would rattle. I figured that someone dropped a bulb in it, but before I did something with itI needed to find out why it rattled so.
So let the autopsy begin. (IMG:style_emoticons/default/screwy.gif) 930 Tach - so what makes these so damn expensive (IMG:style_emoticons/default/confused24.gif) That little 1 bar boost gauge hosed in the face. (IMG:style_emoticons/default/confused24.gif) Tools of the trade - custom made for this job. Opens gauge bezels like a can opener. Just work your way around, at least 3/4 of the way. All opened up (IMG:style_emoticons/default/piratenanner.gif) Flip it over remove three screws and one nut. And removed from the can More Detail just for you Tim (IMG:style_emoticons/default/beer.gif) Interior of the can And now what was rattling around inside the tach. (IMG:style_emoticons/default/poke.gif) I was right (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/happy11.gif) Can't wait to see what happens to this now (IMG:style_emoticons/default/shades.gif) |
timothy_nd28 |
Nov 12 2017, 09:01 PM
Mechanically, I would just reuse the boost motor as the fuel gauge motor. You may need to change the resistor, but it's minor work. Re-stenciling the face plate would be the bigger issue.
The needle for the boost gauge isn't in its proper resting point, is your boost gauge broken? There should be a hair spring attached to the needle shaft so the needle returns back to zero. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:13 PM |
