SOT: 930 Tach disassembly FT! is rattling in there?, Unless your running a boosted -6 |
914forme |
Nov 12 2017, 07:58 PM
So I have a 930 Tach, and every time you rolled it around it would rattle. I figured that someone dropped a bulb in it, but before I did something with itI needed to find out why it rattled so.
So let the autopsy begin. (IMG:style_emoticons/default/screwy.gif) 930 Tach - so what makes these so damn expensive (IMG:style_emoticons/default/confused24.gif) That little 1 bar boost gauge hosed in the face. (IMG:style_emoticons/default/confused24.gif) Tools of the trade - custom made for this job. Opens gauge bezels like a can opener. Just work your way around, at least 3/4 of the way. All opened up (IMG:style_emoticons/default/piratenanner.gif) Flip it over remove three screws and one nut. And removed from the can More Detail just for you Tim (IMG:style_emoticons/default/beer.gif) Interior of the can And now what was rattling around inside the tach. (IMG:style_emoticons/default/poke.gif) I was right (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/happy11.gif) Can't wait to see what happens to this now (IMG:style_emoticons/default/shades.gif) |
914forme |
Nov 13 2017, 11:19 AM
Well, here is the real skinny on this.
The boost gauge portion is not broke, it goes full right with out a resistance source. That is a big plus. So it is working as intended. 930 parts carry a cult status with them. I completely understand why, but just saying for what it is it is not that big of a deal. (IMG:style_emoticons/default/confused24.gif) Certainly not worth the $$$.$$ being offered on Ebay for (IMG:style_emoticons/default/ar15.gif) Yes you can add a fuel gauge movement to the tach with the help of some friends. You can do it with a stock face plate and some carful drilling. and then a couple of tick marks, a vinyl stencil would most likely do the trick. and then a bit of 1 shot and a nice brush. Or 1 shot and an airbrush. Add a small spot for the low fuel warning light to go, and well you got a working gauge. And a very nice trick combo gauge. Mark what are you running that you need more gauges? Speedo Tach - add 1 and a Quad or Triple gauge. With the Quad you can have 5 (other) gauges, that is a lot of gauges. My 914-6 Oil temp / Pressure, and fuel. Guess I could add cylinder head temp or two for both banks and move the fuel over to the Tach. Quad is easily made via a 924 combo gauge. My EG build Oil Presuure Oil Temp Water Temp Fuel ? - but if I use the 930 tach, then I would keep it a 930 tach and add positive pressure to the intake side. (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 05:00 AM |
