Cold weather driving |
Grosbard |
Nov 12 2017, 09:19 PM
Member Group: Members Posts: 88 Joined: 29-September 09 From: Pasadena, CA Member No.: 10,862 Region Association: Southern California |
I haven't driven my car in cold weather yet, and I have a couple of questions for you more experienced guys.
So far I've only driven the car on warm, or moderate days (70 degrees and up). It is having an overheating issue. i.e. engine temp gets too high after 60-90 minutes of highway cruising on a hot day, so I have to pull over and let the car cool down. Then I'm fine again for another 60-90 minutes. The overheating issue needs to be fixed, and it will be taken care of this winter. In the meanwhile, I might take a drive in the near future. The current weather here in the northeast is around 40-50 degrees fahrenheit. So my questions are: 1. Would the outside air temperature being 40 or 50 degrees significantly change my overheating issue to the point where it won't be a problem, or in the grand scheme of things is the engine so much hotter than 20-30 degree difference in ambient temperature, so it won't make much difference. 2. I don't have a heater in the car (another thing that will be resolved this winter). Do you guys think it would be too cold in the car for a drive with my wife on a 40 degree day (or a 20 degree day), or would the heat radiating from the engine compartment keep the cabin pretty comfy once the car has warmed up a bit? Thanks for all your help! |
mepstein |
Nov 12 2017, 09:51 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The 914 looses heat quickly. I drove my first 914 through the winter without any heat and it was rough. But I was 17 and didn’t know about heat exchangers. The biggest problem is the windshield fogs up and the only way to keep it clear is to open a window. Your wife will hate it.
The good thing about a 914 is a working heat system will almost fry you out of the car, even on a cold day. That’s with the heat on high, you can always turn it down. Don’t bother trying to heat the car with little electric heaters. It doesn’t work. I copied this screenshot from pelican because it shows how the math won’t add up to heat your car with electric. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:50 AM |
