Cold weather driving |
Grosbard |
Nov 12 2017, 09:19 PM
Member Group: Members Posts: 88 Joined: 29-September 09 From: Pasadena, CA Member No.: 10,862 Region Association: Southern California |
I haven't driven my car in cold weather yet, and I have a couple of questions for you more experienced guys.
So far I've only driven the car on warm, or moderate days (70 degrees and up). It is having an overheating issue. i.e. engine temp gets too high after 60-90 minutes of highway cruising on a hot day, so I have to pull over and let the car cool down. Then I'm fine again for another 60-90 minutes. The overheating issue needs to be fixed, and it will be taken care of this winter. In the meanwhile, I might take a drive in the near future. The current weather here in the northeast is around 40-50 degrees fahrenheit. So my questions are: 1. Would the outside air temperature being 40 or 50 degrees significantly change my overheating issue to the point where it won't be a problem, or in the grand scheme of things is the engine so much hotter than 20-30 degree difference in ambient temperature, so it won't make much difference. 2. I don't have a heater in the car (another thing that will be resolved this winter). Do you guys think it would be too cold in the car for a drive with my wife on a 40 degree day (or a 20 degree day), or would the heat radiating from the engine compartment keep the cabin pretty comfy once the car has warmed up a bit? Thanks for all your help! |
bbrock |
Nov 13 2017, 08:29 PM
It's impossible to say whether you will be cold. Around here a 30 degree and sunny day is a candidate for top off driving. It just depends on your tolerance and how you dress. But I agree with Mark that window fogging is your real problem. That can make it downright dangerous.
As others have said, the 914 heating system is awesome. I remember many days driving with the top off in the 40s and 50s and being perfectly comfortable. Roll up the windows and turn the heat up full, and it is amazing how warm the cabin stays. Contrast that with the VW bus we used to have with a perfectly functioning heating system (which is the equivalent of lighting a match in a barn). I remember one very cold Christmas driving home to the folks for the holiday. Even with the heat cranked, the wife and I were both bundled in high end winter mummy sleeping bags. I had to unzip the foot to stick my frozen toes out to run the peddles, and kept an ice scraper in one hand to frequently scrape the frost off the inside of the glass. One great thing about a 914 in the snow is that if you get stuck, you can often stick a leg out the open door and push yourself out without even getting out of your seat! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:22 AM |
