Cold weather driving |
Grosbard |
Nov 12 2017, 09:19 PM
Member Group: Members Posts: 88 Joined: 29-September 09 From: Pasadena, CA Member No.: 10,862 Region Association: Southern California |
I haven't driven my car in cold weather yet, and I have a couple of questions for you more experienced guys.
So far I've only driven the car on warm, or moderate days (70 degrees and up). It is having an overheating issue. i.e. engine temp gets too high after 60-90 minutes of highway cruising on a hot day, so I have to pull over and let the car cool down. Then I'm fine again for another 60-90 minutes. The overheating issue needs to be fixed, and it will be taken care of this winter. In the meanwhile, I might take a drive in the near future. The current weather here in the northeast is around 40-50 degrees fahrenheit. So my questions are: 1. Would the outside air temperature being 40 or 50 degrees significantly change my overheating issue to the point where it won't be a problem, or in the grand scheme of things is the engine so much hotter than 20-30 degree difference in ambient temperature, so it won't make much difference. 2. I don't have a heater in the car (another thing that will be resolved this winter). Do you guys think it would be too cold in the car for a drive with my wife on a 40 degree day (or a 20 degree day), or would the heat radiating from the engine compartment keep the cabin pretty comfy once the car has warmed up a bit? Thanks for all your help! |
McMark |
Nov 16 2017, 08:08 AM
If you have overheating problems it's because there's a problem. Driving with a problem, even if it's not manifesting, is risky. If the overheating is caused by incorrect fuel mixture or ignition timing then those things can be causing increased wear and tear.
So without knowing WHAT is causing the overheating, I wouldn't drive it. I would spend the time to fix it. |
dcheek |
Nov 16 2017, 09:19 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
If you have overheating problems it's because there's a problem. Driving with a problem, even if it's not manifesting, is risky. If the overheating is caused by incorrect fuel mixture or ignition timing then those things can be causing increased wear and tear. So without knowing WHAT is causing the overheating, I wouldn't drive it. I would spend the time to fix it. Could also be a mouse nest between the cooling tins and cylinders. You can have a look without removing the engine with one of those probe cameras. Dave |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:12 AM |
