911 Muffler on Six Conversion, Same outlet location? |
mmascari |
Nov 13 2017, 09:58 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I'm looking at buying a 911 muffler (Dansk) for my six conversion but just curious if the outlet is in the same spot as a stock '73 rear valence. I want to be able to utilize my stock rear valence without modification. If not I might just buy one that has dual outlets like the GT style.
Also, is there any benefit to using a dual outlet versus a single outlet? Would the single outlet be restrictive? My engine is a 3.0, J&E pistons, webcam GE60 and PMO carbs. |
mb911 |
Nov 14 2017, 08:14 AM
914 Guru Group: Members Posts: 6,808 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
The bad ass 3.6 and 3.8 would require it but anything less really doesn't though people think in their minds they do .. Think back to the days of American muscle cars just because a person would go to an open airfilter element didn't mean it went faster it just got louder..
Think about a 3.2 in a 911. The stock exhaust seems less then impressive.. To change to a ssi or something similar improves throttle response but not much else. You will see torque improve a touch.. But most cases they still run a 2in 1out becuase there is nothing to gain with dual outlet but noise.. Keep in mind I am not just speculating as I sold thousands of mufflers with real data points when I owned m&k. |
Justinp71 |
Nov 14 2017, 12:03 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
The bad ass 3.6 and 3.8 would require it but anything less really doesn't though people think in their minds they do .. Think back to the days of American muscle cars just because a person would go to an open airfilter element didn't mean it went faster it just got louder.. Think about a 3.2 in a 911. The stock exhaust seems less then impressive.. To change to a ssi or something similar improves throttle response but not much else. You will see torque improve a touch.. But most cases they still run a 2in 1out becuase there is nothing to gain with dual outlet but noise.. Keep in mind I am not just speculating as I sold thousands of mufflers with real data points when I owned m&k. Interesting. I have a M&K 2in / 2 out. The standard version where you can plug up one side and make it a single out. It felt like it gained hp when I un-capped the second port, but your saying its all in my mind? I'm running a carbed/cammed 3.2, about ~280hp at the crank. |
mepstein |
Nov 14 2017, 12:31 PM
914-6 GT in waiting Group: Members Posts: 19,237 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The bad ass 3.6 and 3.8 would require it but anything less really doesn't though people think in their minds they do .. Think back to the days of American muscle cars just because a person would go to an open airfilter element didn't mean it went faster it just got louder.. Think about a 3.2 in a 911. The stock exhaust seems less then impressive.. To change to a ssi or something similar improves throttle response but not much else. You will see torque improve a touch.. But most cases they still run a 2in 1out becuase there is nothing to gain with dual outlet but noise.. Keep in mind I am not just speculating as I sold thousands of mufflers with real data points when I owned m&k. Interesting. I have a M&K 2in / 2 out. The standard version where you can plug up one side and make it a single out. It felt like it gained hp when I un-capped the second port, but your saying its all in my mind? I'm running a carbed/cammed 3.2, about ~280hp at the crank. You have a really hot engine. 280 is a lot for a 3.2. I bet your car rips. |
Justinp71 |
Nov 14 2017, 01:15 PM
The bad ass 3.6 and 3.8 would require it but anything less really doesn't though people think in their minds they do .. Think back to the days of American muscle cars just because a person would go to an open airfilter element didn't mean it went faster it just got louder.. Think about a 3.2 in a 911. The stock exhaust seems less then impressive.. To change to a ssi or something similar improves throttle response but not much else. You will see torque improve a touch.. But most cases they still run a 2in 1out becuase there is nothing to gain with dual outlet but noise.. Keep in mind I am not just speculating as I sold thousands of mufflers with real data points when I owned m&k. Interesting. I have a M&K 2in / 2 out. The standard version where you can plug up one side and make it a single out. It felt like it gained hp when I un-capped the second port, but your saying its all in my mind? I'm running a carbed/cammed 3.2, about ~280hp at the crank. You have a really hot engine. 280 is a lot for a 3.2. I bet your car rips. Ya it rips pretty good . I've never dynoed it, but there is the same combo of parts from a guy on pelican and he's at 250hp to the wheels (~290hp at the crank with a 915). It's definitely more power than you need on the street. http://forums.pelicanparts.com/porsche-911...fore-after.html |
Lo-Fi Version | Time is now: 24th April 2024 - 09:17 AM |
