Need help with some wire issues |
aharder |
Nov 18 2017, 09:32 PM
Advanced Member Group: Members Posts: 4,372 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
So I'm doing the dash, front pad, windshield project and I found
what looks like a Pulled Broken Wire This is a red wire with a red strip that comes off of the tach. Didn't find any wires broken anywhere |
JeffBowlsby |
Nov 19 2017, 12:11 AM
914 Wiring Harnesses Group: Members Posts: 8,480 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Does this help?
Spoke |
Nov 19 2017, 08:55 AM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The '75 schematic in my Haynes manual has that wire being Red with white stripe and also goes to K3, G1, K16, and K2.
Where: G1 = Fuel gauge K3 = Oil pressure indicator light K16 = Low fuel warning light K2 = Generator charge indicator light (GEN light) Can't tell which one that wire came from. Likely it pulled out of another spade connector. |
GregAmy |
Nov 19 2017, 09:09 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Edit duh, can't type fast enough. What he said! ^^^
Is not that wire spliced off from the #11 terminal on the tach? If so, it's 12V power. Ck all your gauges and find out who's missing a 12V power source. Anything not working? My electrical diagrams show that wires is spliced into the following: - #11 on the tach - power for the oil pressure indicator light - power for the fuel gauge - power for the low fuel light - power for the gen charge light |
aharder |
Nov 19 2017, 12:11 PM
It has all 5 of the connections. Starting at 6, then goes to 7, then to 8, then to 2, and then to the tach at 11, The chart above shows 2 red wires for 6,7,2 but not 8 and 11. Since I can't find any other connection that is missing a wire or sign of a torn wire so I think I will cap it off and put it back together and see if anything is not working. Thanks for your input !! |
Lo-Fi Version | Time is now: 26th April 2024 - 06:19 PM |
