Are all FI trigger points created equal?, Will points from a 1.7 work with a 2.0? |
KELTY360 |
Nov 19 2017, 01:39 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I've got an 009 dizzy and want to know if the trigger points are compatible with a stock '75 2.0 dizzy.
914_teener |
Nov 19 2017, 02:26 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Nov 19 2017, 04:56 PM
What "009" distributor do you have? There is one that is from a 1.8 liter, and it doesn't have FI trigger points. There is one that is completely aftermarket, and it also doesn't have FI trigger points.
If you have a D-jet distributor (1.7 or 2.0) the trigger points are the same. Also for the D-jet VWs, I believe, and possibly other D-jet cars. Pics might help as well. --DD |
KELTY360 |
Nov 19 2017, 05:14 PM
What "009" distributor do you have? There is one that is from a 1.8 liter, and it doesn't have FI trigger points. There is one that is completely aftermarket, and it also doesn't have FI trigger points. If you have a D-jet distributor (1.7 or 2.0) the trigger points are the same. Also for the D-jet VWs, I believe, and possibly other D-jet cars. Pics might help as well. --DD My 009 is a Bosch unit I got years ago with a '72 parts car. It has trigger points that appear to be in good working condition. Sounds like they are compatible with all D-jet FI. |
Nov 20 2017, 07:18 AM
Custom Member Group: Members Posts: 24,563 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
As far as I can tell, it’s a binary switch that goes off at 180 degrees
They all look the same to me. Vw 411 Volvo p1800 Porsche 914 |
Root_Werks |
Nov 20 2017, 08:49 AM
Village Idiot Group: Members Posts: 8,306 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Don't use used points unless your stranded.
Get some "002" points, put them along side the points you remove or the points in the 009 dizzy. You'll see why they are better. 911-602-936-00-M1002 |
JeffBowlsby |
Nov 20 2017, 09:08 AM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Not all DJet trigger points are the same. Benz DJet cars use trigger points that are different than those for 914s and VDubs.
rhodyguy |
Nov 20 2017, 01:19 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Confused. Marc, are you talking fi or spark points?
KELTY360 |
Nov 20 2017, 01:32 PM
Confused. Marc, are you talking fi or spark points? Hate to do this to you Kevin, but you might want to read the title of the thread. (IMG:style_emoticons/default/slap.gif) (I never get to use that smiley...feels so good) |
Root_Werks |
Nov 20 2017, 02:21 PM
Confused. Marc, are you talking fi or spark points? Hate to do this to you Kevin, but you might want to read the title of the thread. (IMG:style_emoticons/default/slap.gif) (I never get to use that smiley...feels so good) If you're going there Marc, your title says FI Trigger points and 009 dizzy's don't have FI trigger points so (IMG:style_emoticons/default/slap.gif) If you are talking spark points, ditch the 011 and get a 002 set used on early 911's with CD boxes. They are heavier springs and larger contact area. They can take a pounding and should drop right into any dizzy that uses the 011 points. If you need FI trigger points, good luck. |
KELTY360 |
Nov 20 2017, 02:37 PM
Confused. Marc, are you talking fi or spark points? Hate to do this to you Kevin, but you might want to read the title of the thread. (IMG:style_emoticons/default/slap.gif) (I never get to use that smiley...feels so good) If you're going there Marc, your title says FI Trigger points and 009 dizzy's don't have FI trigger points so (IMG:style_emoticons/default/slap.gif) If you are talking spark points, ditch the 011 and get a 002 set used on early 911's with CD boxes. They are heavier springs and larger contact area. They can take a pounding and should drop right into any dizzy that uses the 011 points. If you need FI trigger points, good luck. Now I'm confused, Dan. I've got a Bosch dizzy: PN#0 231 174 009 that definitely has FI trigger points. What the hell is it? |
JeffBowlsby |
Nov 20 2017, 02:42 PM
Brad Anders page says that 0231174009 is the Bosch PN, for 039905205 Porsche PN which is the 1973 2.0L dizzy. Its D-Jet.
KELTY360 |
Nov 20 2017, 02:54 PM
JeffBowlsby |
Nov 20 2017, 03:06 PM
Its normal to have both numbers.
Root_Werks |
Nov 20 2017, 03:16 PM
Yep, sorry Marc, thought you were refering to one of the "009" aftermarket angular accerlation dizzy's.
KELTY360 |
Nov 20 2017, 03:25 PM
Yep, sorry Marc, thought you were refering to one of the "009" aftermarket angular accerlation dizzy's. Think you're getting off that easy? (IMG:style_emoticons/default/slap.gif) What are you up to dude? (IMG:style_emoticons/default/grouphug.gif) |
Root_Werks |
Nov 20 2017, 04:31 PM
Yep, sorry Marc, thought you were refering to one of the "009" aftermarket angular accerlation dizzy's. Think you're getting off that easy? (IMG:style_emoticons/default/slap.gif) What are you up to dude? (IMG:style_emoticons/default/grouphug.gif) Still no 914, but have my 76's standard FI bug. Mostly fly these days, no time or money for cars anymore. Airplanes are more fun. Some day, I'd like to get another 914. (IMG:style_emoticons/default/driving.gif) |
rhodyguy |
Nov 20 2017, 07:34 PM
Hate to do this to you Marc....As previously noted, the 009 is the common ID for a centrifical advance dist used on carbed cars. That you later added the complete number after the fact eases the confusion. At least on my end. Amazing that the COMPLETE numbers is identical to one in Jeff's post.
Lo-Fi Version | Time is now: 25th April 2024 - 05:15 PM |
