lifts, 4 post |
lifts, 4 post |
80cap |
Nov 21 2017, 01:02 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
anyone own one of these? wildfirelifts.com
sithot |
Nov 21 2017, 01:12 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Capacity number? (IMG:style_emoticons/default/popcorn[1].gif)
Triaddave |
Nov 21 2017, 02:08 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
I have a two post BENDPAC. It is rated at 7000 lbs and picks our cars at the four buttons on the bottom of the chassis. It is great for changing tires or brake work because it picks the frame, not the tires.
I cost me less than $2500 including the power (240 v) and oil. shipping was free from bendpac. It also lifts engines, or cars off engines, lawn mowers and sheetrock up to the loft, the pick-up truck......It will come with ALL your friends too. |
Triaddave |
Nov 21 2017, 02:41 PM
davehg |
Nov 21 2017, 04:01 PM
Member Group: Members Posts: 183 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
I just did a fair amount of research on 2 and 4 post lifts before making my purchase. I didn't come across the above company as one of the top few rated companies, but there are a ton of lift providers out there - almost all of them are Chinese manufacturers.
My review demonstrated that the top rated units - rated by both performance, service, and price, were Rotary, BendPak, and Mohawk. Rotary and Mohawk were more expensive. BendPak seems to occupy a nice niche at the "prosumer" level - more expensive and arguably better made than most of the Chinese brands, but perhaps not the perfect solution for a working garage with heavy duty cycles and needs. Based on research and feedback from a few pals who had been down this path, I ended up with a Bendpak 4 post 14XL lift, and added oil changing pan, 7000lb rolling jack, and a few other options. The lift capacity was huge - 14,000lbs and the extended wheel base because I wanted to be able to lift and service my RAM crew cab diesel - which weighs 8000lbs but has 4700 lbs over the front axle thanks to the heavy Cummins engine. It's not enough to examine just the overall capacity - you have to also know how much weight over the front and rear axles you are lifting to ensure your lift is safely within limits. This lift was overkill for any 914 - but necessary for the truck. A two post lift might be ideal for the 914 - it is not as stable for long term storage but costs less and takes up less space. You should really have 6" concrete base to safely use a 9klb lift and more if you are lifting 14k lbs- the benefit of a 4 post lift is that you don't need as thick of a base. Plus, it makes an awesome storage platform. My experience with Bendpak has been super positive - they've overnighted some parts out ASAP (I broke the Zerk fittings) and the quality of the lift is very high. Online reactions are similar - responsive and fast customer service. I paid to have mine installed - it wasn't cheap but watching the 2 guys sweat for 5+ hours made me glad I did. Total cost for the lift, install, and options was about $7.7k - a smaller lift or a 2 post unit would have been about $2k cheaper. For both, you'll need to run a 220 line from your electric panel (they make a 120v line but it lifts slowly). Also need a small pancake style compressor to power the air locks. The unit lifts via hydraulic power, not air. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1511301702.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1511301703.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1511301704.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1511301704.4.jpg) |
douglastic |
Nov 21 2017, 05:13 PM
not a real person Group: Members Posts: 58 Joined: 7-November 16 From: Beaumont, CA Member No.: 20,566 Region Association: Southwest Region |
Unobtanium-inc |
Nov 21 2017, 06:29 PM
Advanced Member Group: Members Posts: 2,202 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
I got two from my local NAPA, so I saved on shipping. The manager is a Porsche buddy so he even came to my house and installed them for me. They are made by Challenger/Quality which I think is the cheap brand of Snap-On. I just installed the 2nd one last weekend. Two fit in my 2 car garage. They were about $3000 each and come complete with ramps and drip trays.
https://www.napaonline.com/en/p/CL_Q4P07 I'm picking up the 4th car from the paint shop on Friday, then they can all sleep together all winter, like a slumber party! Attached thumbnail(s) |
Triaddave |
Nov 23 2017, 12:49 PM
I see advantages and disadvantages of both. I bought my Bend Pac 20- some years ago,
It is built in the USA. They did have a larger unit I was thinking of buying, like 9000 lbs., but mostly, I lift 914,911 some MG's and once in a while the Silverado, (4-5000 lbs.) Again, I like lifting the chassis for brake/wheel work. As far as steady, My car was up when the Nisqually earthquake hit, all tires off. I was working in Seattle that day and all I could think of was my 4 bent rotors. The car was as I left it when I got home, still up on the hoist!! Now, I lower it if I can for the night..... |
rhodyguy |
Nov 23 2017, 12:55 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
For the PNW, Greg Smith Equipment, Clacamas, offers some nice products at what seems to be reasonable pricing.
Triaddave |
Nov 23 2017, 01:46 PM
One more thing....The vehicle dolly really come in handy for storing cars in tight places, or in my case, turning car side ways so three cars fit in one bay. I bought these (4) at harbor freight for under $100.00.
SKL1 |
Nov 23 2017, 02:12 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I've got a Direct Lift (I assume Chinese) from local PHX dealer who installed it. 110V- a little slow in lifting but happy with it. Quality fine for what I use it for. Came with drip trays and I got the rolling jack which is really handy and recommended highly.
My son just got a 2 post from Greg Smith (Atlas, also Chinese we assume) and loves it... |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:21 AM |
