Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
zig-n-zag |
Dec 25 2017, 11:55 PM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
Different intake manifolds created the width difference. Your manifolds have a sharper turn into the head, whereas the cb manifolds have a gentler turn. The cb manifolds are also taller. I use those dell carb gaskets as a soft mount of sorts, though i cut them apart so they fit flat. The cb crossbar for type4/914 is longer, for type1 shorter. The ball ends supporting the crossbar look cobbled together which led me to think that's a type1 length bar made to work. Check the part numbers on your air cleaner base plates and see if they are for type1 or 4 with cb. Good luck, have fun.
Lo-Fi Version | Time is now: 6th May 2024 - 09:24 PM |
