Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
HarveyH |
Nov 25 2017, 01:15 PM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Once upon a time long, long ago in a galaxy far, far away (pre-internet) I was researching recommendations for a jetting for Weber 40 IDF's on a 2056 with a hot cam. I called several Weber suppliers, and they all recommended major upgrades to the ignition system as a starting point. This included a multi-spark box, upgraded coil and a point replacement system. I went with the Crane Hi-6 and PS-91 coil and a Pertronix and it made a major improvement in driveability.
As time went by, the internet came along and I found out the 009 distributor the Previous Owner installed was nor really suitable for Ty4 engine. The Mallory was recommended, but the original equipment Bosch would be vastly superior to the 009. Since the PO had included the original distributor with the car, I reinstalled that and again found a significant improvement in driveability. Harvey |
Lo-Fi Version | Time is now: 20th April 2024 - 04:26 AM |
