Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
MarkV |
Nov 28 2017, 10:09 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I didn't realize that dual carbs don't produce a good vacuum signal but it makes sense. I didn't find a port on the DRLA's with a vacuum signal and I didn't want to drill them.
I have a cross bar linkage because it came with the car and it was at one time all that was available. It's probably harder to set up but once it's set it works fine. Just make sure that both sides open at the same rate. The jets are marked ..... easy to enough to read. You can pull a venturi with out having to remove the carb by just pulling the top off the carb. They have a cone shaped set screw on the end of the barrel. The venturi are marked. I am running 34's you made need something bigger. If you take the top off a carb be careful not to damage the gasket or inadvertently bend the float tangs and change the fuel level. Do a search here I am sure there are a bunch of threads concerning dialing in carbs. This one is pretty useful: http://www.aircooled.net/synchronize-dual-...arburetors-103/ |
Lo-Fi Version | Time is now: 19th April 2024 - 05:09 PM |
