Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
rhodyguy |
Dec 15 2017, 08:30 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Back the pass side idle speed adj screw off of the stop. Does the engine stumble or a marked change in the idle? Using the driver's side, pass side off stop, turn the idle up to 1.3k. Now measure the flow on the front venturi of both carbs. You want a stable needle on the flow measuring tool. Now you can control/increase the idle speed with ONLY the driver's side ISAS. Matched at idle means nothing if the flow measurements change when the linkage is working. You don't want to be dropping a c-note + per hour for a linkage problem or needs carbs rebuilt "diagnosis".
When idling, filter tops off, and you glance down the carbs do you note any fuel dribbling? You don't need to spend $ on an additional flow measurement device. |
Lo-Fi Version | Time is now: 25th April 2024 - 06:42 AM |
