Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
Mark Henry |
Dec 17 2017, 04:06 PM
Just googled I was thinking dellorto "Jet Doctor" which was made to solve a dell jet issue,
Below is the gaskets I'm talking about, MarkV here's where you can get them and many other dell parts. http://vwparts.aircooled.net/Dellorto-DRLA...stle-gasket.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/vwparts.aircooled.net-26-1513548379.1.jpg) |
98101 |
Dec 17 2017, 05:01 PM
Just googled I was thinking dellorto "Jet Doctor" which was made to solve a dell jet issue, Below is the gaskets I'm talking about, MarkV here's where you can get them and many other dell parts. http://vwparts.aircooled.net/Dellorto-DRLA...stle-gasket.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/vwparts.aircooled.net-26-1513548379.1.jpg) I noticed that site says: QUOTE correct torque for the 4 mount nuts is 10-15 INCH lbs. We also suggest tightening in a criss-cross pattern and bring the nuts down slowly to torque. Lastly, we recommend running a spring style lock washer under your nuts Maybe those instructions weren't followed in this case? |
Lo-Fi Version | Time is now: 25th April 2024 - 10:05 PM |
