Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
MarkV |
Dec 25 2017, 11:44 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
It looks like the hex bar is adjusted all to way to one side for some reason. The pivots for the hex bar that hold tension on the springs are adjustable. In one of the photos the pivot is almost all the way inside the hex bar and in the other photo the pivot is adjusted most of the way out.
The angles you have highlighted in green are pretty much fixed. The angle from side to side is the angle that you want to make sure is symmetrical. If one of those bars has a different angle than the other the carbs aren't going to open in unison. I have a cheap magnetic base angle finder/gauge from Harbor Freight that I used when I set my carbs up that helped me get it right. |
98101 |
Dec 26 2017, 12:06 AM
It looks like the hex bar is adjusted all to way to one side for some reason. The pivots for the hex bar that hold tension on the springs are adjustable. In one of the photos the pivot is almost all the way inside the hex bar and in the other photo the pivot is adjusted most of the way out. Tonight I didn't detect a spring on the right side of the hex bar, only on the left. The angles you have highlighted in green are pretty much fixed. The angle from side to side is the angle that you want to make sure is symmetrical. If one of those bars has a different angle than the other the carbs aren't going to open in unison. I have a cheap magnetic base angle finder/gauge from Harbor Freight that I used when I set my carbs up that helped me get it right. I'm 60% sure I understood the part about angle from side to side, but I'm spacially challenged so please bear with me as I confirm: the angles of the two linkage rods (the funny-threaded rods with heim joints at each end) against the carbs when viewed from above the engine lid? |
Lo-Fi Version | Time is now: 29th March 2024 - 08:18 AM |
