Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
IronHillRestorations |
Dec 26 2017, 10:28 AM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
From what I can see in post #43 the thick intake gasket is deformed and leaking air. It looks to me like you can see the inner edge of the gasket has been squeezed out. The carbs will never sync up if you have a big intake gasket leak.
Ditch the hex cross bar and get a CSP bellcrank. I found a CSP type 4 kit at Mid-America Motorworks for $125, even if you paid another $50 it's worth it. Think of the CB cast hex bar as a linkage from a Yugo, and the CSP as from a Porsche. There's that much of a difference. https://www.csp-shop.com/en/engine/type-4-b...ida-23951b.html |
Lo-Fi Version | Time is now: 25th April 2024 - 09:51 AM |
