Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
MarkV |
Jan 4 2018, 08:21 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Needle nose pliers or small set of vice-grips. Put it back together and leave everything loose and then wind up the spring and get it in place last before you tighten the nut.
(IMG:style_emoticons/default/confused24.gif) |
98101 |
Jan 5 2018, 01:10 AM
Needle nose pliers or small set of vice-grips. Put it back together and leave everything loose and then wind up the spring and get it in place last before you tighten the nut. (IMG:style_emoticons/default/confused24.gif) Following Mark's advice, and considering Perry's experience that half a turn is enough, I managed to get the spring this far. I don't have a fish scale to measure the exact force, but it snaps back smartly and intuitively feels like the right amount of force for throttle return. Per the CSP instructions for Weber IDF, I torqued the SW11 throttle control shaft nut to 4 ft/lbs. I'm guessing the right number for DRLA would be similar, and doubt the previous owners bothered with a torque wrench anyway. The lock tab wasn't done up before. I guess I should do that. Maybe you tall guys could do all this with the carbs in place on the engine? I don't see how I could have done it without pulling the carb. |
Lo-Fi Version | Time is now: 28th March 2024 - 11:30 PM |
