Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
98101 |
Jan 5 2018, 02:18 AM
I had to use more like 8 ft/lbs of torque (twice the amount in the instructions) to get the SW11 throttle control shaft nut to align with the lock tab. I hope The Maker will forgive my transgression.
UPDATE: I found this picture of "properly installed tab washer" online. I do not see how my tab washer can perform its function on the CSP throttle lever, and wondering if I should just replace it with a conventional washer. (Or ignore this as a trivial issue and keep going with the CSP installation since it's taking longer than I expected.) |
Lo-Fi Version | Time is now: 18th April 2024 - 10:10 PM |
