Keep Dellorto DRLA 45s and Bosch 009? |
98101 |
Nov 25 2017, 05:44 AM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I suddenly find myself owning 1970 4-cylinder 2.4 with Web hot street Cam idles nicely and pulls hard at WOT. Part throttle response is not great, often with carbs coughing and even backfiring on trailing throttle. My use is mostly street, so I'd like to get this part throttle stuff sorted.
Here's pictures of the stuff that's in there now. I guess that's the infamous Bosch 009 with no vacuum advance and a PerTronix 1847A. The carbs are Dellorto DRLA 45s with short velocity stacks and these tall foam things that don't seal against the air cleaner housings. I'm willing to learn about the carbs but I don't have much confidence in the 009 for running nicely on the street. Please correct me if I'm wrong about any of this stuff. Also from other threads I gather that switching to EFI such as MicroSquirt would cost $5K or so ... though I'm not ruling this out completely. Correct me if I'm wrong about that. Is this kind of linkage OK? Here's the idle you may have seen in another post: https://www.youtube.com/watch?v=-AC53RRrXOU Any help you can provide is appreciated! --Michael in Seattle |
98101 |
Jan 9 2018, 09:13 PM
I didn't try adjusting the CSP linkage until the next day. I used both the fingertip technique I learned from you guys (touching one while looking at the other), and also tried using paper as a feeler gauge, like a zero-lash valve adjustment. From the photo you'll see I used the CSP installation instructions for paper. This was the only use I got from the instructions, as they were written for IDFs not DRLAs.
When I tested with the air-flow meters later, the left and right carb were more in sync than I had ever gotten them before. (But there were other, much worse problems I'll describe next.) |
Lo-Fi Version | Time is now: 25th April 2024 - 10:46 PM |
