my first porsche, is it worth it? |
440gordy |
Nov 26 2017, 05:41 PM
Newbie Group: Members Posts: 11 Joined: 26-November 17 From: washington state Member No.: 21,638 Region Association: Pacific Northwest |
I am about to buy this 914. it has a little rust but nothing i cant handle. Both the lower rocker tins are rusted out and there is a spot on the threshold where the rocker meets the door striker panel. Needs a battery tray and maybe bracket. some surface rust along the back trunk but should clean up easily. no rust in the front compartment. It is supposed to have a slipping clutch, probably oil soaked from a leak. all in all a really straight car. I did get it started for about 30 seconds by bypassing the fuel pump and using another pump and running fuel direct from a gas can and it sounded just fine. It appears to have 106k. if i purchase this i plan to tear it to the ground and repaint it completely. and make any needed repairs. I don't want to overpay for it and then be buried in it. From what i have stated can any of you give me a good starting purchase price and possible end value. any knowledge form you guys would be greatly appreciated!! |
440gordy |
Dec 3 2017, 09:18 PM
well i finally got the deal done with the owner and i got it for $600.
It will need minor rust repair, mostly surface rust. will need to replace the jack tube on one side of the frame rail. The Hell Hole below the battery tray has surface rust but it is not rusted through nor is the opposite side either. all in all it appears to be a great car. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:51 PM |
