Help: Strange Oil Filter and Findings., ...What the hell is going on? |
CptTripps |
May 26 2005, 08:40 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Ok...ALL I wanted to do was change my oil. Simple enough?
I started by driving to Stoddard to pick up an OEM Filter. $8.65 later, I was on my way. Got home, backed the car up to the ramps and drained the oil. Didn't seem to take that long. (More on that later) Pulled the filter, and drained it. Oiled up the ring on the new filter and went to dry-fit the new one (just to make sure) and it is NOWHERE CLOSE to the same size as the one I pulled. I'm going to say that the one that was on there is 1/2 the size. There is NO way I could get the new one in there. If I WERE able to, the thread size was different. (New one is larger hole.) So NOW the question was...what filter do I buy? It was an STP filter, so off I went to FLAPS to match it up. FLAPS didn't carry the brand, so I had to locate a book with a decent cross-reference in it so I could get something that DID fit. I found 4-5 filters that matched it, so I bought them all (I wasn't going back!) and headed home to look at the link to the "Filter Shootout" that I found earlier. (Interesting read!) I ended up with an AC Delco filter that matched my size/thread. I checked the codes on it, and it's manufactured by Champion, who also makes the Mahle (sp?) filters that we get from Germany. Installed in a snap, and I started filling her back up. So Question one is ... What the hell did the DAPO do? The SECOND question is...I only drained 1.5q of oil out of there. But the level was even with the top line. I put 1q of Slick-50 in, and then put 4 more of Mobil-1 Synthetic back in. I'm now a good 1/2" above the top line, but I have a 2.0L engine WITH an external cooler. There is NO WAY that I can only be using 1.5q of oil...is there? I don't want to fry this thing...any ideas? |
scotty914 |
May 26 2005, 08:45 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
did you make sure the oil cooler drained out too. and 5 quarts is too much on a stock car they were ment to hold about 3.5 to 3.75. do you know how much your cooler holds for sure, maybe you where low.
CptTripps |
May 26 2005, 08:51 PM
I had the car backed onto ramps, and the filter was WAY high, and the drain lines were pointed that direction. I can only assume that it drained. I didn't drain it specificly though.
I'm thinking I'm going to see if I can drain a quart or so out of there tomorrow. Hell, maybe I'll drain the wole thing while it's flat and start over? With where the drain plug is, and the angle I had the motor at, I can't see it holding more than 1/2q that I didn't drain. I've only put about 500mi on the car, and the last oil change was the DAPO....who kows when ago. The oil that DID come out was B-L-A-C-K! Strange that I didn't get higher temps. I've been hovering around 180...even in traffic for 45min today. |
dmenche914 |
May 26 2005, 08:56 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
You say you have an external cooler. My guess is the strange oil filter size needed is the result of the fitting used on the engine to get the oil too and from the external cooler. That fitting is sandwiched between the filter and the filter fitting on the engine case. You are smart to stick with a OEM manufactured filter, some national "namebrand" filters are junk on 914's
You will need to fill the oil too past the dip stick mark by at least the volume of oil that drains back from the cooler. You need to verify how much extra fill is needed for you application and oil lines. You external cooler should have a thermostat, to keep it out of the loop until the oil heats up, be sure one is installed. Best advice is to install an oil pressure gauge, very easy to install, and vital for monitoring your engines oil supply, it also will give you a clue to an over heating condition, cause the oil will thin out and pressure will drop. The 914 can handle so well, that the factory found it had to install an oil baffle plate in the engine bottom to help prevent oil starvation in cornering, some engines lack these, an oil pressure gauge will tell you, cause you can see the pressure drop on a tight turn! Be sure the factory cooling air deflector flaps are installed, and operable, if the automatic thermostat fails, the flaps fail in the "safe" position, some misguided "mechanics" have mistakenly removed them, or wired them in the shut position! so check the cooling system carefully on any new car. Also Valve adjustments are fairly frequent on these aircooled beasts. Why you drained out only 1.5 quarts I do not know. Good luck!!!! |
redshift |
May 26 2005, 08:58 PM
should drain out mostly if level.. stock.
I use a gallon, stock... and leave maybe a cup or so in the jug.. for sippin... M |
CptTripps |
May 26 2005, 09:03 PM
I put a pressure sensor in the other day, but I think I have it wired wrong somewhere b/c it is PEGGED all the way. I'm not sure I have it grounded properly. I'll take care of that in the morning before I drive it to work.
Good to know on the filter. As long as it still filters, I guess I'll be in good shape. I'm going to put a fan on the external cooler in the coming weeks, so I'll dig into that when I cross that bridge! Anyone else have an opinion on this??? |
rick 918-S |
May 26 2005, 09:12 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
The 1 1/2 quart level is a little un-nerving.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Do you have an inline "T" stat on the oil cooler? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) It may have been closed and trapped the oil in the cooler. Just a thought. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Lo-Fi Version | Time is now: 8th May 2024 - 11:39 AM |
