Front Brake Rotor Bearing Caps 1973, Factory/Aftermarket Seal? |
Costa05 |
Nov 29 2017, 05:38 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Q. Do the front bearing caps (domes) have a rubber seal gasket that goes on first? If so what is the part number and where to find. seal only that is. Checked various suppliers with no luck.
Thanks in advance for any reply. Rich |
Mikey914 |
Nov 29 2017, 05:47 PM
The rubber man Group: Members Posts: 12,646 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Found it no real information other than it exists. I do recall it now. It was basically an o ring.
Should be an ace hardware part |
914Sixer |
Nov 29 2017, 07:46 PM
914 Guru Group: Members Posts: 8,871 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Yep, go to your local hardware store.
Mikey914 |
Nov 29 2017, 07:57 PM
If anyone knows the size I'll bring in a crapton and make them available cheap..I can check tomorrow if no one knows.
Mark |
mepstein |
Nov 29 2017, 08:23 PM
914-6 GT in waiting Group: Members Posts: 19,246 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I wouldn’t mind an O ring for the 911 front hub. Paying $2.50 for them gets old.
mgphoto |
Nov 29 2017, 08:24 PM
"If there is a mistake it will find me" Group: Members Posts: 1,337 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
only /4 use this 421.839.455, but the parts book has it part of the /6 assembly.
Absorbent foam rubber, used to pick up the grease slung passed the cap. NLA years ago. |
jim_hoyland |
Nov 29 2017, 09:02 PM
Get that VIN ? Group: Members Posts: 9,265 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How does that O-ring sit; in a groove, or ??
Mikey914 |
Nov 29 2017, 09:06 PM
My recollection is that it was a standard rubber O ring. If it is other I can still do, just might as well make it the same or better. If I recall it just sat on the base of the cap to deter crap from getting in.
mepstein |
Nov 29 2017, 09:20 PM
rgalla9146 |
Nov 29 2017, 09:46 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
dubl
rgalla9146 |
Nov 29 2017, 09:49 PM
It was not hard rubber.
I was softer .....and it had a seam. Haven't seen one in years. I fit behind the rim of the grease cap. |
mgphoto |
Nov 29 2017, 09:59 PM
Mikey914 |
Nov 29 2017, 11:47 PM
Well I know a guy that makes rubber stuff.
Just curious if the new reproduction caps have the same ridge. I'm doubting it. But please post up some pics. Mark |
Costa05 |
Nov 30 2017, 12:50 AM
Mikey914 |
Nov 30 2017, 12:19 PM
Can you measure the thickest part? I think these could be easily made.
Costa05 |
Nov 30 2017, 02:06 PM
Mikey914 |
Nov 30 2017, 02:31 PM
Thanks,
Just trying to determine the original thickness as best as possible. |
11tenths |
Nov 30 2017, 04:14 PM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
Wow, never knew these existed. Maybe it'll help make removal of
those caps a little easier. |
Costa05 |
Nov 30 2017, 09:48 PM
Can you measure the thickest part? I think these could be easily made. I will tonight when I get home. They are pretty ragged but I should be able to get it for you. 3 mm would be a good guess. It is kind of a foamy rubber material if that matters. I would be more than happy to send them to you for your archival R & D division. (IMG:style_emoticons/default/biggrin.gif). Headed to the trash otherwise. (IMG:style_emoticons/default/beerchug.gif) |
mgphoto |
Dec 11 2017, 05:07 PM
Lo-Fi Version | Time is now: 30th April 2024 - 05:11 PM |
