Another GB from 914rubber.com - Bet you cant break these. SOLID STAINLESS, Rear trailing arm Bushings and support rod $120 for the set |
restore2seater |
Dec 1 2017, 11:51 PM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
I'm in for a set.
Mikey914 |
Dec 4 2017, 04:44 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
PMs sent to all this far
bdstone914 |
Dec 4 2017, 08:13 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm still trying to decide on these. I want to stay as close to the factory ride and feel as possible since I always thought that was about as perfect as it gets for a street car. When you say the rubber bushings were difficult to install, does that mean impossible, or just that you would need a press? And are rubber bushings off the table based on your experience with them? I think I'm in, but I'm totally clueless about how much harder bushings translate to ride comfort. Hopefully, it is negligible. (IMG:style_emoticons/default/smile.gif) I bought and installed a set of the rubber bushings by Elephant Racing. Took me 12 hours and a lot of swearing with the tools they supply. The problem is with getting the shaft pressed into the bushing. The shaft wants to bunch up the bushing and push it out of place. Seems to be a science to install them using the right amount of heat and lubricant to get the shaft to slide into the bushing. The poly bushing act more like a bearing with the bushing rotating around the shaft. The rubber bushing act more like a spring as the shaft is fixed in position to the car. The dampening effect or the rubber is gone when using the poly bushing. I am not saying this is bad, just different. Poly is going to act more like the true bearing similar to the poly bronze ones. |
BeatNavy |
Dec 4 2017, 08:30 AM
I bought and installed a set of the rubber bushings by Elephant Racing. Took me 12 hours and a lot of swearing with the tools they supply. The problem is with getting the shaft pressed into the bushing. The shaft wants to bunch up the bushing and push it out of place. Seems to be a science to install them using the right amount of heat and lubricant to get the shaft to slide into the bushing. (IMG:style_emoticons/default/agree.gif). And just in case you want to know more about the process and the associated pain: http://www.914world.com/bbs2/index.php?sho...276229&st=0 |
bbrock |
Dec 4 2017, 08:47 AM
I bought and installed a set of the rubber bushings by Elephant Racing. Took me 12 hours and a lot of swearing with the tools they supply. The problem is with getting the shaft pressed into the bushing. The shaft wants to bunch up the bushing and push it out of place. Seems to be a science to install them using the right amount of heat and lubricant to get the shaft to slide into the bushing. (IMG:style_emoticons/default/agree.gif). And just in case you want to know more about the process and the associated pain: http://www.914world.com/bbs2/index.php?sho...276229&st=0 Thanks guys! I ordered my set last week. Figured for the price and ease of installation, these are worth a go. Based on your replies, I think I made the right decision. (IMG:style_emoticons/default/biggrin.gif) |
sbsix |
Dec 4 2017, 10:29 AM
only the lead dog enjoys a change in scenery... Group: Members Posts: 448 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
Mark, I'm in for a set.
bozo914 |
Dec 4 2017, 11:18 AM
Slacker Group: Members Posts: 284 Joined: 27-October 10 From: Richmond VA Member No.: 12,325 Region Association: MidAtlantic Region |
Add me to the list. I'm in for a set.
76-914 |
Dec 4 2017, 06:56 PM
Put me down for a pair. I can't stand the creaking and crackling of the Urethane bushings much longer.
bigkensteele |
Dec 4 2017, 07:35 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Well, I need them, so I am in.
rudedude |
Dec 4 2017, 08:52 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I’ll need two complete sets ,all front and rear pieces and one installation tool
Jule |
Norskpole |
Dec 5 2017, 12:39 AM
Member Group: Members Posts: 60 Joined: 18-April 10 From: Oceanside, CA Member No.: 11,628 Region Association: Southern California |
I'm in for a set...thanks!
mgp4591 |
Dec 5 2017, 03:32 AM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Mark, would those of us with great bushings but less that perfect shafts (that sounds a little strange...) be able to purchase only the stainless shafts?
Mikey914 |
Dec 5 2017, 10:31 AM
Yes I could sell you the shafts only for $20 less during the GB. PM sent.
Mueller |
Dec 5 2017, 10:44 AM
Add me the list please... and for the front a-arms. Thanks,
Mblizzard |
Dec 5 2017, 12:26 PM
Mblizzard |
Dec 5 2017, 12:27 PM
duplicate
Mikey914 |
Dec 6 2017, 12:12 AM
If you do want just the shafts PM me I can set this up, but we do recommend installing with these bushings.
brownaar |
Dec 6 2017, 07:03 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Crap! I'll take a set.
Mblizzard |
Dec 6 2017, 07:08 AM
Dec 6 2017, 09:48 AM
914-6 GT in waiting Group: Members Posts: 19,237 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Crap! I'll take a set. I hate how he comes up with things that are just amazing and you have to buy! Well my bank account hates it. I love it! (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 24th April 2024 - 05:10 PM |
