GB from 914Rubber.com A- Arm bushings CLOSING 12/23, $29/59 a set add tools for $30 adtnl. Reg price $48/80 |
Mikey914 |
Nov 30 2017, 11:50 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As many of you may be aware there has been a "Cheap" option, that lets say brand "E" has done a video on notating that they are smaller than factory and change the pre-load on the arm.
Brand "U" lets call them has an install video saying that they have recreated the factory part with the same "type and amount of rubber being used" Technically not true because as shown in the video by brand E the durometer is definitely not the same from the deflection noted. With all the BS aside we have made a part like the factory bushing and a special tool to help install these. One of the problems with installation of this part is the end that brand E glosses over. When you get to the part where the tube holds that end from sliding down the shaft you have a "sharp edge" from the metal the rubber can catch on. If it catches you will scar the inside rubber. This will make a second attempt more difficult. We have made the delrin "tools" to allow you to use a 1/2" stainless rod with some nuts and large washers to install. There is a taper to allow the rubber to clear the edge of the A arm without catching it. I had Cary do up one for me and fully document this so that you will have some instruction as how to do this. We are currently compiling and putting this together now. Attached thumbnail(s) |
Mikey914 |
Nov 30 2017, 11:54 AM
To be clear the delrin parts are the only "tools" we are providing. We figured that most of you have an Ace Hardware or Home Depot nearby and can acquire these for less than we can ship them for.
BeatNavy |
Nov 30 2017, 12:00 PM
Yup, I'll need one set of these with the tool.
It would have been two but I already bought a set of "brand E" about 8 weeks ago. From the looks of it, this is a great value, and I could have saved a decent chunk of money. Oh well. |
Mikey914 |
Nov 30 2017, 12:04 PM
Yup, I'll need one set of these with the tool. It would have been two but I already bought a set of "brand E" about 8 weeks ago. From the looks of it, this is a great value, and I could have saved a decent chunk of money. Oh well. What is their return policy? I'd pay you postage (IMG:style_emoticons/default/biggrin.gif) |
GregAmy |
Nov 30 2017, 12:10 PM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Perfect timing. I'm in.
Also will go along with other winter projects, including the door/seal rebuilds kits (with all options), and how are you coming on the targa/top seals? |
BeatNavy |
Nov 30 2017, 12:12 PM
Yup, I'll need one set of these with the tool. It would have been two but I already bought a set of "brand E" about 8 weeks ago. From the looks of it, this is a great value, and I could have saved a decent chunk of money. Oh well. What is their return policy? I'd pay you postage (IMG:style_emoticons/default/biggrin.gif) They probably wouldn't be thrilled that I've done a "partial install" (bushings are in the collars, but not on the arms). Otherwise I'd take you up on it (IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
Nov 30 2017, 12:16 PM
Perfect timing. I'm in. Also will go along with other winter projects, including the door/seal rebuilds kits (with all options), and how are you coming on the targa/top seals? we are finishing up the tools on the lathe now. Will be able to start shipping in a few days (tools) Also doing a set of GBs aimed at suspension so we will be able to combine to the extent possible. There is one more I need to list but need to run a few errands 1st. |
MikeM |
Senior Member Group: Members Posts: 558 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Fantastic price!!
Sadly, I also installed brand"E" last spring. |
mepstein |
Nov 30 2017, 12:33 PM
914-6 GT in waiting Group: Members Posts: 19,215 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’ve been waiting on these. Thank you.
mepstein |
Nov 30 2017, 12:38 PM
To be clear the delrin parts are the only "tools" we are providing. We figured that most of you have an Ace Hardware or Home Depot nearby and can acquire these for less than we can ship them for. (IMG:style_emoticons/default/agree.gif) I just recently bought some threaded rod, nuts and washers to install some motorcycle headset cups and it was less than $10. |
mb911 |
Nov 30 2017, 01:16 PM
914 Guru Group: Members Posts: 6,798 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am in but you knew that.
bbrock |
Nov 30 2017, 01:19 PM
I've also been waiting, so I'm in.
Mikey914 |
Nov 30 2017, 02:28 PM
We've also marked our product so you will not get imposters
Chris914n6 |
Nov 30 2017, 03:06 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
These also fit the 911 arms right?
Are rear trailing arm bushings in the works? |
CMONNETT |
Nov 30 2017, 03:51 PM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
I'd be interested in one maybe two sets.
Thanks, |
amfab |
Nov 30 2017, 03:57 PM
Member Group: Members Posts: 391 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
K i'm in
rmdinmd |
Nov 30 2017, 04:29 PM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
in for a set. thx
JamesM |
Nov 30 2017, 04:59 PM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Id love to see a video to see how much of a PITA this is, but im in, with tools. two of my cars are on 45 year old rubber and the 3rd is on $500 worth of RSR parts so this seems like its worth a shot.
dlee6204 |
Nov 30 2017, 06:34 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm in
bigkensteele |
Nov 30 2017, 07:59 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
An early set of the bushings somehow landed in my mailbox, and the quality is first-rate. Compared to the poly bushings I was about to use, they are a no-brainer.
I still need to get my A-arms powder coated, but as soon as that is done, these are going on! |
Lo-Fi Version | Time is now: 18th April 2024 - 05:26 AM |
