Delete please, Thanks |
jt914 |
Dec 1 2017, 09:02 PM
I love my914 Group: Members Posts: 26 Joined: 20-March 14 From: Pinon Hills, CA Member No.: 17,141 Region Association: Southern California |
Hi guys, I have a lot of 914 parts that need to go. i have all sorts of stuff from all over the cars. If there is anything you need let me know and i'll let you know if i have. prices can't be beat and the more you buy the better the deals. thanks
jason Here is some of it: Front Brake calipers $40 Brake Pistons $5each Brake Hardware $1 and up Master Cylinders $25 Proportioning Valve $25 Hard Brake Lines $5ea Brake Dust Shields$5ea Rear Valance$100 Rear Bumper Core$50 Dog Bones$1ea Fiberglass Rocker panel pair$50 Hella Tail Light Lens pair$100 Hella Side Marker assembly and lens$25ea Tail Light Plastic Nuts$FREE Headlights$10 Headlight Motors$20 Turn Signal Buckets$20 Fuel Injection ECU $50 FI Harnesses$50 1.7 205F Distributors$50 Trigger Points$50 Relay Boards, Covers, Hold-Down Bolts$5-20 Relays $3ea Fuel Pressure Regulators$30 Deceleration Valves$20 Fuel Rails$2ea Voltage Regulators$10ea 1.7 Djet Injection Parts from 1973 Fuel Pressure Sender Connectors and harness parts Coils$10ea 2.0 Manifold$25 Distributor Drive Gears$25 Rear Trunk Lock$25 Rear Trunk Latch and Plunger$25 Inner Door Lock Mechanism $20 Striker Plates$10pr New Front Trunk Weatherstrip Seal $40 Engine Lid Welting Front Targa Latches $25 Window Roller Assembly $25 Front Cowl Seals $5 Dash Skeleton$50 Steering Column$25 Heater Parts Dash Fresh Air Controls$25 Glove Boxes, Doors$10ea Glove box Lock$15 Window Crank Handles$3 Vents$10 Triangle side window glass$10 Rear window$25 Coat Hooks$10 Front Trunk Release Handle and Lock$15 Pedal Clusters$50 Pedal Cluster Parts Pedal Boards$10 1.7 shortblock has not been split open w crank, cam, rods$200 Cranks 1.7 $50 Connecting Rods 1.7 $50set Rocker Arm Assembly 2.0 $100 Oil Coolers$10 Pushrods and Tubes$2 1.7 Heat Exchangers blasted and painted$100 1.7 Heads $100 2.0 Head 75-76 needs repair $40 Valve Covers and Bales $30 Driver seat$60 Seat Tracks$25ea Center pad and plastic tray $15 Fuel Combo Gauge Silver Dot$30 Gauge Bezels Metal $20 or Plastic$10 914 A-arms$80 Front Struts and Spindles$50 . And so I don't break any more rules, I wish to be paid in cash. Or paypal if parts need shipped. plus actual shipping and packaging if needed. |
jt914 |
Dec 28 2017, 10:49 PM
I have many 914 parts that I need to sell before I move out of state next month. At the moment I'm concerned about getting rid of some of the bigger things that are most likely not going to make the move.
914 Bare Dash Skeleton Frame with odometer reset cable and nice basketweave vinyl $50 Rear Chrome bumper core $30 Fiberglass Dash needs finishing, can be painted any color $40 Steel Wheels 15 inch various $15 each Seat in good driver condition with just 2 small tears $50 1.7 shortblock $200 1.7 heads pair $80 Nice later Rain Tray with no cracks $40 EMPI type 4 engine stand $70 Front A Control Arm pair with factory bracket mount for drop links $60 steering racks $25 Targa Top late nice condition with latches $200 Targa top early no latches fair condition $75 fan shroud with alternator. has dipstick hole thru alternator tin for rear facing VW application $40 front spindle $40 901 SideShift Transaxle $300 Rear Window Glass $20 later inner window roller mechanisms $20 1.7 1.8 steel heat exchanger pair in good shape. blasted and hi temp paint coating $100 Front Brake calipers $40 Brake Pistons $5each Brake Hardware $1 and up Master Cylinders $25 Proportioning Valve $25 Hard Brake Lines $5ea Brake Dust Shields$5ea Rear Bumper Core$50 Dog Bones$1ea Fiberglass Rocker panel pair$50 Hella Tail Light Lens pair$100 Hella Side Marker assembly and lens$25ea Tail Light Plastic Nuts$FREE Headlights$10 Headlight Motors$20 Turn Signal Buckets$20 Fuel Injection MPS$50 Fuel Injection ECU $50 FI Harnesses$50 1.7 205F Distributors$50 Trigger Points$50 Relay Boards, Hold-Down Knurled nut $5-20 Relays $3ea Fuel Pressure Regulators$30 Deceleration Valves$20 Fuel Rails$2ea Voltage Regulators$10ea 1.7 Djet Injection Parts from 1973 Fuel Pressure Sender Connectors and harness parts Coils$10ea 2.0 Manifold$25 Distributor Drive Gears$25 Exterior Door Handle Pair Driver Quality$75 Rear Trunk Lock$25 Rear Trunk Latch and Plunger$25 Inner Door Lock Mechanism $20 Striker Plates$10pr New Front Trunk Weatherstrip Seal $40 Engine Lid Welting Front Targa Latches $25 Window Roller Assembly $25 Front Cowl Seals $5 Dash Skeleton$50 Steering Column$25 Heater Parts Dash Fresh Air Controls$25 Glove Boxes, Doors$10ea Glove box Lock$15 Window Crank Handles$3 Vents$10 Triangle side window glass$10 Rear window$25 Coat Hooks$10 Front Trunk Release Handle and Lock$15 Pedal Clusters$50 Pedal Cluster Parts Pedal Boards$10 1.7 shortblock has not been split open w crank, cam, rods$200 Cranks 1.7 $50 Connecting Rods 1.7 $50set Rocker Arm Assembly 2.0 $100 Oil Coolers$10 Pushrods and Tubes$2 1.7 Heat Exchangers blasted and painted$100 Heat Valve Flappers $20 1.7 Heads $100 2.0 Head 75-76 needs repair $40 Valve Covers and Bales $30 Shifter Sideshift$50 sold Shifter Tailshift$50 Driver seat$60 Seat Tracks$25ea Center pad and plastic tray $10 Fuel Combo Gauge Silver Dot$30 Gauge Bezels Metal $20 or Plastic$10 914 A-arms$80 Front Struts and Spindles$50 various seals and small bits, hardware, screws, nuts, brackets, Porsche 356 rear side panels $100 924/944 door armrest$20 924/944 brake booster $40 I have lots of small bits and will try to start making more lists but there is a lot to go thru. Please buy some of this stuff and lighten my load. I will make deals and everything is negotiable. If you don't like my prices, make an offer. I'm fair. If you want to take it all, make a reasonable offer. Thank you! |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:32 AM |
