Cooling/fan housing |
cal44 |
Dec 2 2017, 08:24 AM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
Lads,
are the cooling/fan housings the same for the 1.7 thru 2.0? I have a 2.0 block and thought I would start piecing together an engine as parts come up for sale on CL. |
Mark Henry |
Dec 2 2017, 08:59 AM
Might have some small differences, early 1.7 has studs to mount the heater aux fan, later maybe smog pump mounting but they all would work.
If it's a bus shroud it won't have the big timing hole on top, so for a 914 it has to be a 914 shroud. |
cal44 |
Dec 3 2017, 07:05 AM
Thank you.
Lo-Fi Version | Time is now: 7th May 2024 - 06:35 PM |
