Who has mounted Mikey’s Fender Liners?, 914 Rubber Issue |
RickS |
Dec 2 2017, 10:28 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Just received the box with the liners. Instead of the stated “clips” for mounting they came with rivets. Clips suggest clipping the liners to the fenders or other attachment points rivets on the other hand... Am a bit hesitant to start drilling holes in my original sheet metal. No instructions were provided either.
Any one done this or have suggestions of the least invasive way they mounted these not using “clips”? |
RickS |
Dec 9 2017, 09:03 PM
Here is my misguided attempt to try to make the piece which matches the one above fit in the back of the front wheel well. I notched it but it still won’t snug up to the fender.
You can see the issue with that tongue piece. When flush mounting the liners against the fender lips how can you access the bolts which mount the L brackets when you want to drop a valence or the rocker panel? When trying to mount the driver rear piece, how did you work around the suspension pieces with the zirk fitting? Seemed to be a lot of interference due to the suspension. |
Lo-Fi Version | Time is now: 17th April 2024 - 05:06 PM |
