Ignition Harness, Another question |
bbrock |
Dec 4 2017, 09:42 AM
The ignition harness from my '73 is fried but I found a harness in my spare parts that needs a few minor repairs, but cleaned up pretty nice.
This may have come out of my old '74 VW bus but is identical to the fried harness with the exception of the size of the yellow wire running to the starter. The wire on the good harness is smaller (probably 2.0/14 gauge) compared with the original harness. I can't find wire sizes on the '73 wiring diagrams, but the '74 diagrams indicate a 4.0 mm^2 wire which would be about 11 gauge. Would you replace that wire? Seems like this one might be size critical. I'm thinking of replacing with 12 gauge. I think 10 gauge might cause fitment problems at the 12-pin terminal. Or is it fine like it is. What do you think? (IMG:style_emoticons/default/confused24.gif) |
JeffBowlsby |
Dec 4 2017, 09:14 PM
914 Wiring Harnesses Group: Members Posts: 8,487 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Photo of the whole harness please. That brown wire is only on the 70-72 ignition harnesses if it is a 914 harness. Not correct for a 73 914. The yellow starter wire increased in size in 1973. Recommend to avoid the starter relays. It's one more thing to fail and if you think you need one, it's an indication of some other problem like dirty connections or grounds, or a bad starter.
bbrock |
Dec 4 2017, 10:21 PM
Photo of the whole harness please. That brown wire is only on the 70-72 ignition harnesses if it is a 914 harness. Not correct for a 73 914. The yellow starter wire increased in size in 1973. Recommend to avoid the starter relays. It's one more thing to fail and if you think you need one, it's an indication of some other problem like dirty connections or grounds, or a bad starter. Now it gets interesting! I think this is out of my old '74 bus. The two wires running to the tach were cut so I need to repair or replace them. Sounds like I'll be upsizing the starter wire too. The brown and green wires threw me because they didn't show up on the '73 schematic. So, I clipped them just behind the male spades and pulled them out. But just as I did so, I thought, "hey, rear window defrost." So I looked at the schematic more carefully and then pulled out your schematic for the rear window defrost. And sure enough, it matched. Then I thought, "Doh! Why did I clip those?" And yes, my bus had a rear window defroster. What I don't know is whether this was how the ignition harness was configured on a '73 914 with the rear window defrost option. Or maybe that option ran with a completely separate harness up to the 12-pin connector? This configuration seems more tidy, and the brown pigtail you noticed is the other end of the brown wire terminating at the plastic connector for the defrost. I'm assuming this is intended to connect to the multi-spade ground on the engine block. I have a rear window with defrost, harness, and switch coming from Chris (tygaboy). So figured I'd sort out the final configuration once I had the defrost harness in hand. But since I have the attention of the expert... (IMG:style_emoticons/default/confused24.gif) I've owned a '70 914/4, two '73 914's, and a '74 bus. So this harness had to come out of one of those. I didn't think rear defrost was an option in '70. I also have an alternator harness with a blue pigtail wire that from some quick googling, connected to the aux heater blower on the bus. So I'm thinking both these harnesses are from the same vehicle. Both alternator harnesses are trashed, so you'll be seeing an order from me before this project is over. (IMG:style_emoticons/default/beerchug.gif) |
JeffBowlsby |
Dec 5 2017, 12:04 AM
See my comments interspersed below.
Photo of the whole harness please. That brown wire is only on the 70-72 ignition harnesses if it is a 914 harness. Not correct for a 73 914. The yellow starter wire increased in size in 1973. Recommend to avoid the starter relays. It's one more thing to fail and if you think you need one, it's an indication of some other problem like dirty connections or grounds, or a bad starter. Now it gets interesting! I think this is out of my old '74 bus. The two wires running to the tach were cut so I need to repair or replace them. Sounds like I'll be upsizing the starter wire too. No, I think it is a 1972-only 914 harness. It's hard if not impossible to replace the wires inside the casing. Don't think it's necessary. The brown and green wires threw me because they didn't show up on the '73 schematic. They would not be in a 1973 harness. They are the two wires for the heater fan in the 1970-72 engine bay. So, I clipped them just behind the male spades and pulled them out. But just as I did so, I thought, "hey, rear window defrost." So I looked at the schematic more carefully and then pulled out your schematic for the rear window defrost. And sure enough, it matched. Um no. The rear window defrost is a separate harness and it does not connect to the 12-pin connector and it routes through the forward fuse on the relay board. It has a special 2-pole female connector. Then I thought, "Doh! Why did I clip those?" And yes, my bus had a rear window defroster. What I don't know is whether this was how the ignition harness was configured on a '73 914 with the rear window defrost option. Or maybe that option ran with a completely separate harness up to the 12-pin connector? This configuration seems more tidy, and the brown pigtail you noticed is the other end of the brown wire terminating at the plastic connector for the defrost. The brown wire is the ground for the heater fan. Note the heater fan is not fused at the relay board other than thru the main fuse. I'm assuming this is intended to connect to the multi-spade ground on the engine block. I have a rear window with defrost, harness, and switch coming from Chris (tygaboy). So figured I'd sort out the final configuration once I had the defrost harness in hand. But since I have the attention of the expert... (IMG:style_emoticons/default/confused24.gif) I've owned a '70 914/4, two '73 914's, and a '74 bus. So this harness had to come out of one of those. I didn't think rear defrost was an option in '70. I also have an alternator harness with a blue pigtail wire that from some quick googling, connected to the aux heater blower on the bus. So I'm thinking both these harnesses are from the same vehicle. Both alternator harnesses are trashed, so you'll be seeing an order from me before this project is over. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:11 PM |
