Ignition Harness, Another question |
bbrock |
Dec 4 2017, 09:42 AM
The ignition harness from my '73 is fried but I found a harness in my spare parts that needs a few minor repairs, but cleaned up pretty nice.
This may have come out of my old '74 VW bus but is identical to the fried harness with the exception of the size of the yellow wire running to the starter. The wire on the good harness is smaller (probably 2.0/14 gauge) compared with the original harness. I can't find wire sizes on the '73 wiring diagrams, but the '74 diagrams indicate a 4.0 mm^2 wire which would be about 11 gauge. Would you replace that wire? Seems like this one might be size critical. I'm thinking of replacing with 12 gauge. I think 10 gauge might cause fitment problems at the 12-pin terminal. Or is it fine like it is. What do you think? (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Dec 4 2017, 09:44 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'd leave it and employee a relay to carry the load to the solenoid. (IMG:style_emoticons/default/beerchug.gif)
bbrock |
Dec 4 2017, 09:49 AM
I'd leave it and employee a relay to carry the load to the solenoid. (IMG:style_emoticons/default/beerchug.gif) Thanks! I forgot to mention that I plan to install a relay. But I haven't looked at the schematics in Mark's how-to to understand how that would impact load on this wire. But now that I think about it, I guess this would be the relay trigger wire. |
76-914 |
Dec 4 2017, 07:00 PM
I'd leave it and employee a relay to carry the load to the solenoid. (IMG:style_emoticons/default/beerchug.gif) Thanks! I forgot to mention that I plan to install a relay. But I haven't looked at the schematics in Mark's how-to to understand how that would impact load on this wire. But now that I think about it, I guess this would be the relay trigger wire. Correct. I prefer the Ford relay over Bosch. Ford requires only 3.8v to open. IIRC, th Bosch is around 9v. |
Lo-Fi Version | Time is now: 25th April 2024 - 11:19 PM |
