Flywheel minimum thickness? |
Cazz |
Dec 6 2017, 03:03 PM
Newbie Group: Members Posts: 13 Joined: 22-December 16 From: NC Member No.: 20,688 Region Association: None |
My flywheel is grooved and needs to be machined.
-Does anyone know the minimum thickness of the flywheel surface where the clutch disc mates? -the thickness I get using my cheap calipers is 4mm thickness on the face. -what is the minimum thickness after a machine shop cuts the face? |
Dave_Darling |
Dec 7 2017, 03:06 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The image is actually specifically for the 914-6. There are no official specs for the 914-4 flywheels that I know of.
The specs should be OK as a general guide, but they are not actually for the four-cylinder flywheels... --DD |
porschetub |
Dec 7 2017, 04:19 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
The image is actually specifically for the 914-6. There are no official specs for the 914-4 flywheels that I know of. The specs should be OK as a general guide, but they are not actually for the four-cylinder flywheels... --DD (IMG:style_emoticons/default/agree.gif) good spotting Dave,thats the drawing I used to check my flywheel,confirmed it was in spec but had been cut maybe once,pulled my gearbox and added a 1mm + spacer under the pivot ball,much improved and the release arm now has clearance on the gearbox housing. The flywheel bolts on the "6" motors aren't an issue...tends to limit resurfacing on a T4 however. |
Lo-Fi Version | Time is now: 26th April 2024 - 10:19 AM |
