wiper arms & blades |
JFG |
Dec 8 2017, 11:22 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Are they the same as late 60's or early 70's 911's?
mgphoto |
Dec 8 2017, 02:27 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Not sure about the 911 but 914's have a straight arm #914.628.313.10 left side "observe installation hints" and angular arm #914.628.314.10 again "observe installation hints" right side.
Both are listed as SWF Install hints would be in the factory repair manual. |
porschetub |
Dec 8 2017, 04:41 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Don't buy the "jp group" brand from pelican ,bought these for my car and they don't fit,someone screwed up (IMG:style_emoticons/default/chair.gif) cause they even have a 911 part number so that will answers your question, (IMG:style_emoticons/default/beer.gif)
EDIT ,just researched and there seems a cross over sorry for the bad info,well it appears that way the ones I have appear to be for a latter 911....still looking as I would like to sell them. |
GeorgeRud |
Dec 8 2017, 05:14 PM
Another issue is with the fit of the Bosch wiper blade plastic adapter. The ones currently packaged with the wiper blades are a bit wide and provide a loose fit on the arm. Frustrating!
Mark Henry |
Dec 8 2017, 05:46 PM
Not sure about the 911 but 914's have a straight arm #914.628.313.10 left side "observe installation hints" and angular arm #914.628.314.10 again "observe installation hints" right side. Both are listed as SWF Install hints would be in the factory repair manual. I could be wrong but doesn't the 911 park on the opposite side? The bend in the one arm may be the wrong way IIRC. |
drem914 |
Dec 8 2017, 05:48 PM
Senior Member Group: Members Posts: 1,025 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Another issue is with the fit of the Bosch wiper blade plastic adapter. The ones currently packeged with the wiper blades are a bit wide and provide a loose fit on the arm. Frustrating! Frustrating, yes they can come loose after an "extended" use of 15 minutes during an early morning drive. (IMG:style_emoticons/default/confused24.gif) |
GeorgeRud |
Dec 8 2017, 05:59 PM
Good project for Mikey914? Save those old Bosch adapters if you still have them.
1adam12 |
Dec 8 2017, 06:01 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Larmo63 |
Dec 8 2017, 07:13 PM
Buy this stuff from Eric at Auto Foreign Services if you want correct.
This is all I buy: https://www.ebay.com/itm/Porsche-1968-to-19...~wAAOSwopRYmrkb He has kits too, arms + blades. Perfect reproductions. |
Dec 8 2017, 07:32 PM
914-6 GT in waiting Group: Members Posts: 19,220 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Buy this stuff from Eric at Auto Foreign Services if you want correct. This is all I buy: https://www.ebay.com/itm/Porsche-1968-to-19...~wAAOSwopRYmrkb He has kits too, arms + blades. Perfect reproductions. That’s a great price. My supplier is $26/arm (IMG:style_emoticons/default/sad.gif) |
porschetub |
Dec 8 2017, 11:22 PM
Another issue is with the fit of the Bosch wiper blade plastic adapter. The ones currently packeged with the wiper blades are a bit wide and provide a loose fit on the arm. Frustrating! Had the same issue found some off a Golf or BMW and they worked took up the slop ,the ones provided where completely wrong,shame cause they were well made, used Bosch blades on other euro cars for years and no issues. Bugger really (IMG:style_emoticons/default/sad.gif) . |
Mark Henry |
Dec 9 2017, 10:32 AM
Can you still get refills for bosch blades?
I always use to just replace the squeegee, but FLAPS around here don't seem to carry them anymore, |
porschetub |
Dec 9 2017, 01:25 PM
Turns out Pelican sent me arms for 911 MY 1976 - 1991 (IMG:style_emoticons/default/mad.gif) ,oh well at least I know what I have now.
The earlier arms 911 MY 1968 - 1975 appear to cross over to the 914 ,the 911 number is in fact 914 628 314 00 (rh side). I noticed prices all over the place, genuine was $123 down to $45- 35 for reproduction ones. My old wiper blades were SWF so presume the arms are too ,maybe thats the issue with the Bosch part on those arms (IMG:style_emoticons/default/confused24.gif) |
porschetub |
Dec 9 2017, 01:54 PM
Buy this stuff from Eric at Auto Foreign Services if you want correct. This is all I buy: https://www.ebay.com/itm/Porsche-1968-to-19...~wAAOSwopRYmrkb He has kits too, arms + blades. Perfect reproductions. Thanks for the heads up Lawrence I will order a set from them (IMG:style_emoticons/default/beerchug.gif) . |
Mikey914 |
Dec 9 2017, 07:57 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Always will to tale a look if there's no good options.
76-914 |
Dec 11 2017, 09:46 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,484 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Another issue is with the fit of the Bosch wiper blade plastic adapter. The ones currently packaged with the wiper blades are a bit wide and provide a loose fit on the arm. Frustrating! Timely post. I had just ordered a pair of Bosch from Pelican. I was on the phone @ 0700 changing them to Porsche. I remembered the the last set I bought didn't fit worth a Continental Damn. (IMG:style_emoticons/default/fyou1.gif) Now I know why. (IMG:style_emoticons/default/beerchug.gif) |
bbrock |
Dec 11 2017, 10:14 AM
Another issue is with the fit of the Bosch wiper blade plastic adapter. The ones currently packaged with the wiper blades are a bit wide and provide a loose fit on the arm. Frustrating! Timely post. Disagree!!! (IMG:style_emoticons/default/sad.gif) I think I threw away my blade holders with good fitting adapters a couple months ago when I was stripping my car down. (IMG:style_emoticons/default/headbang.gif) Wish I'd seen this post beforehand. Maybe I'll get lucky and find that I tossed them into one of the many plastic tubs of parts. |
mgphoto |
Dec 11 2017, 10:20 AM
Can you still get refills for bosch blades? I always use to just replace the squeegee, but FLAPS around here don't seem to carry them anymore, FLAPS makes more off the entire blade ($10-15) , so they don't carry them in stores, the refills ($1-3) can be purchased online but shipping usually make them cost prohibitive. |
simonjb |
Nov 13 2018, 06:30 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Where are folks getting wiper blades these days? and what brand?
raynekat |
Nov 14 2018, 12:05 AM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Buy this stuff from Eric at Auto Foreign Services if you want correct. This is all I buy: https://www.ebay.com/itm/Porsche-1968-to-19...~wAAOSwopRYmrkb He has kits too, arms + blades. Perfect reproductions. I have these too. They are "correct" looking and the best of quality. |
Lo-Fi Version | Time is now: 19th April 2024 - 08:34 AM |
