cleaning the inside of the turn signals and tail lights, how do I get the chrome clean? |
914 RZ-1 |
Dec 9 2017, 01:24 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Before I do anything that might damage them, how do I clean the chrome on the inside of the front turn signals and also the rear tail lights?
I was going to use dish soap and water, but thought I might ask if there was a better way. They are dirty and there are a few spots where the chrome is bubbling/chipping, but it's not bad. Can I polish them with anything? |
JFG |
Dec 9 2017, 01:50 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
For the front buckets i had to do a lot of work.
1 thoroughly cleaned. 2 medium to fine sanding 3 i used a coarse paste on a small (dremmel) polushing pad. 4 i finished them with a fine paste and a large domed polishing pad on a slow speed drill. They came up very nice. M My rears were so worn and previously painted that i had to use a chrome reflective vynil to recover the inside reflector wells. |
Dec 9 2017, 02:56 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I used Brasso. Wasn't great, but it seemed to make what was there a bit shinier. I may wind up putting some of the aluminum flue tape in so the shiny back of it serves as a reflector.
--DD |
Front yard mechanic |
Dec 9 2017, 04:48 PM
Senior Member Group: Members Posts: 1,153 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
chrome spray paint worked for me I bought a small can years ago and it has lasted many a tail light housing
GeorgeRud |
Dec 9 2017, 04:52 PM
Has anyone ever had them rechromed? I imagine that would be the best way to restore them, but $$$.
76-914 |
Dec 10 2017, 09:46 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
chrome spray paint worked for me I bought a small can years ago and it has lasted many a tail light housing (IMG:style_emoticons/default/beerchug.gif) Even a fresh coat of a bright silver paint makes an amazing difference. (IMG:style_emoticons/default/beerchug.gif) |
mgphoto |
Dec 12 2017, 09:52 AM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I was thinking of chrome powder coating for the front turn signal buckets.
Dec 12 2017, 09:54 AM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Costa05 |
Dec 12 2017, 11:42 AM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Bright aluminum colored spray paint looks very good and reflective.
Specracer |
Dec 12 2017, 05:39 PM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
+1, my chrome was gone in the tail lights. I used the "chrome" rattle can. I sprayed every area (even where some of the chrome still was) so the amount of reflectivity is the same across the entire area of the tail light
Spoke |
Dec 13 2017, 04:36 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
On the Triumph Experience website, a TR6 owner found a good way to cost effectively "re-chrome" the reflectors. In his words:
I used the Avery chrome vinyl film on the exterior light reflectors to enhance the brightness of the bulbs. |
Krieger |
Dec 13 2017, 08:30 PM
Advanced Member Group: Members Posts: 4,693 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
On the Triumph Experience website, a TR6 owner found a good way to cost effectively "re-chrome" the reflectors. In his words: I used the Avery chrome vinyl film on the exterior light reflectors to enhance the brightness of the bulbs. Wow! The best results I've seen. I did the aluminum reflective had tape and it turned out pretty good. |
914 RZ-1 |
Dec 13 2017, 10:13 PM
Thanks for all the replies! So it appears I can use some sort of chrome tape or paint.
What about cleaning it beforehand? Is dish soap and water okay? |
forrestkhaag |
Dec 17 2017, 11:47 AM
In my case, I used Harbor Freight Tools chrome "HVAC" duct tape. Front and back buckets / The same product is available at Home Depot etc. and has returned the interior of each fixture to a very bright reflective surface and is Windex-wipe-cleanable, desert heat doable, and down right seeable.
At the time, I replaced the seals with 914 Rubber seals and have never opened them up again in three years of almost daily driving. Sidebar: As I was driving home at dusk yesterday along PCH a blue 914-4 passed me up on the #3 lane in Newport Beach headed south then up Newport Coast road. By the time he was 500 feet ahead of me, his rear panel was but a squint-inkling of candle power light. That car needs a bucket-job and thy right soon! Peace to all in the Christmas Season Attached image(s) |
Dec 17 2017, 12:28 PM
Buy some of Spoke’s LED lights. Much brighter than stock and run cooler so they are better for wires and lens
forrestkhaag |
Dec 18 2017, 11:46 AM
Good suggestion: Do you have a prefered source and are the LED versions plug-n-play? (IMG:style_emoticons/default/beerchug.gif)
clapeza |
Dec 18 2017, 12:22 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Spoke's boards are "plug and play" inasmuch as they plug right into the existing bulb sockets, but they are boards of an array of high-intensity LEDs. They far out perform any simple bulb-replacement LED. They take the reflector out of the equation - they fill the entire lens area with LEDs.
They are here: https://www.spokeworksled.com/914-led-solutions ...and he's running a sale right now! I have them in my 914 and in my 911, and they are brilliant, in every sense of the word. |
Dec 18 2017, 12:57 PM
Spoke's boards are "plug and play" inasmuch as they plug right into the existing bulb sockets, but they are boards of an array of high-intensity LEDs. They far out perform any simple bulb-replacement LED. They take the reflector out of the equation - they fill the entire lens area with LEDs. They are here: https://www.spokeworksled.com/914-led-solutions ...and he's running a sale right now! I have them in my 914 and in my 911, and they are brilliant, in every sense of the word. Outstanding product and customer service and you are supporting a vendor that supports 914’s. |
BillC |
Dec 18 2017, 05:24 PM
Senior Member Group: Members Posts: 534 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Spoke's boards are "plug and play" inasmuch as they plug right into the existing bulb sockets, but they are boards of an array of high-intensity LEDs. They far out perform any simple bulb-replacement LED. They take the reflector out of the equation - they fill the entire lens area with LEDs. They are here: https://www.spokeworksled.com/914-led-solutions ...and he's running a sale right now! I have them in my 914 and in my 911, and they are brilliant, in every sense of the word. Outstanding product and customer service and you are supporting a vendor that supports 914’s. +1 I have a full set of Spoke's lights on my car. |
aharder |
Dec 18 2017, 06:11 PM
Advanced Member Group: Members Posts: 4,365 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Spoke's boards are "plug and play" inasmuch as they plug right into the existing bulb sockets, but they are boards of an array of high-intensity LEDs. They far out perform any simple bulb-replacement LED. They take the reflector out of the equation - they fill the entire lens area with LEDs. They are here: https://www.spokeworksled.com/914-led-solutions ...and he's running a sale right now! I have them in my 914 and in my 911, and they are brilliant, in every sense of the word. Outstanding product and customer service and you are supporting a vendor that supports 914’s. +1 I have a full set of Spoke's lights on my car. (IMG:style_emoticons/default/agree.gif) I have front and rear and I think they are great !! |
Lo-Fi Version | Time is now: 19th April 2024 - 08:53 PM |
