Fuse box cover, buy a new cover or a new panel |
slotty008 |
Dec 10 2017, 03:57 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
The cover of my fuse box is missing. I can buy a new cover from Sierra Madre or get a new fuse panel. But Jwest doesn't have it at the moment and Pelican neither. I could buy a 12 way fuse box on Ebay but I'm not sure it will fit
I have had no electrical issues, so what would be the best thing to do? |
Spoke |
Dec 12 2017, 07:54 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
As an EE, I wouldn't change the fuse panel unless there's something wrong with the original unit. Disturbing 40+ year old wiring is the best way to induce other wire/connector-related issues or mixing up wires.
If you like the modern fuses and are game to changing the fuse boxes, go for it. I would just clean all contacts and install new fuses. You must have a cover on the original box for the fuse box to be secure and enable robust and worry-free operation. Just my $0.03. |
Rand |
Dec 12 2017, 09:52 PM
As an EE, I wouldn't change the fuse panel unless there's something wrong with the original unit. Disturbing 40+ year old wiring is the best way to induce other wire/connector-related issues or mixing up wires. If you like the modern fuses and are game to changing the fuse boxes, go for it. I would just clean all contacts and install new fuses. You must have a cover on the original box for the fuse box to be secure and enable robust and worry-free operation. Just my $0.03. I respect your experience, but that's like saying you shouldn't upgrade an OLD VW from a 6V electrical system. If 40 years old doesn't tell you what's wrong with it, the only other thing is accidentally knocking the obsolete chicklets loose. Upgrading things on your car isn't harmful if you do it right. Don't be afraid to make improvements to your car. My $0.01. (IMG:style_emoticons/default/smile.gif) New cars use blade fuses for a reason. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:09 PM |
