FS: Fuel tank, seats, brake lines, Maintenance items, service kit, fuel lines, bulbs, fuses, etc |
bixs |
Dec 10 2017, 04:37 PM
Newbie Group: Members Posts: 9 Joined: 11-May 11 From: Irvine, CA Member No.: 13,061 Region Association: None |
Everything came off a 1970 914 that was likely pieced together with parts. I no longer have the car so I'm just trying to clean out my parts surplus.
*Update: 3/10/2018 ADDED a bunch of smaller items* 1. Fuel tank, SOLD 2. Seat bracket SOLD 3. Seats SOLD 4. fuel cap SOLD 5. fuel filler neck SOLD 6. Fuel tank straps SOLD 7. Cunifer brake lines, (Product page says: Porsche 914 all except 75-76) SOLD ---------------------------------------------------------------------- Service kit from AutoAtlanta (was $100) Asking $60 1. Oil filter 2. Fuel filter 3. Continental alternator belt 4. Bosch spark plugs 5. Bosch contacts 6. Bosch rotor 7. Bosch distributor cap 8. o ring for distributor 9. Ignition condensor 10. 2 cork valve cover gaskets ---------------------------------------------------------------------- Victor Reinz Fuel Injector base seals and tip seals, $1 for 8 total seals SOLD ---------------------------------------------------------------------- Genuine Porsche Tapered Fuel Hose for Connection at Fuel filter, 70-74 1.7/1.8/2.0 SOLD ---------------------------------------------------------------------- VDO Fuel Tank sending unit gasket 1.7/1.8/2.0 (1970-76), SOLD ---------------------------------------------------------------------- Victor Reinz Intake Manifold gaskets 1.7/1.8 1970-1975, $7 for 2 gaskets ---------------------------------------------------------------------- Stainless Steel Tunnel Fuel Line Set (one 8mm and one 9.5mm), 914 (1970-74), SOLD ---------------------------------------------------------------------- Stainless Steel Engine Compartment Fuel Line Set (NOTE: 1970-74 cars also use tapered fuel hose 914-356-525-00-M100), 914 (1970-76), SOLD ---------------------------------------------------------------------- Victor Reinz cork valve cover gaskets, $5 for 2 ---------------------------------------------------------------------- Fuse Kit - 911, 912, 930, 924, 928 1978-84, 944 1982-85.5 914 Fuse Assortment SOLD Bulb Kit - Assortment $3 |
bdstone914 |
Dec 11 2017, 05:37 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What does that tank look like inside? Outside looks pretty rusty. I would try to remove those aluminum nuts on the bottom.
Lo-Fi Version | Time is now: 24th April 2024 - 08:51 AM |
