Adding Heat to the Clown Car |
davebrossi |
Dec 13 2017, 10:05 AM
Member Group: Members Posts: 52 Joined: 6-December 11 From: Idaho Falls, Idaho Member No.: 13,868 Region Association: None |
Apologies for going quiet for months, but I'd burnt out trying to solve the overheat issue on the clown car. Turns out at 5k miles, the fan belt was stretched/heat damaged. no more overheating. (IMG:style_emoticons/default/beerchug.gif)
Now, in case you're wondering about the whole title/point of this thread, I have been bitten by the bug that whispers "what you really need is heating!" as I live in Idaho where they don't salt the roads, but where it's below freezing much of the year. I'll be searching/educating myself in exactly what I need to do, but in the meantime I thought I'd offer a window/way for people to follow along in the adventure. To recap; The Clown Car has a 3.2 from an 87 911, straight headers (which -will- be available once I'm done, hint hint) and it uses a custom engine mount/tin from Rich Johnson. I have opted to go for as close to a stock heat exchanger system as possible over an aux gas heater due to concerns over my ability to cause vehicles to catch fire (I lost an 81 Vanagon to fire.) Based on what I've been able to piece together thus far, in addition to custom headers that mate up to the 3.2's larger diameter exhaust ports, I will need; -flapper valves (I'm assuming the 'custom' part of the headers means I can utilize standard 914 flapper box assemblies.) -aircraft grade fresh air ducting from flapper boxes to longitudinals -the 'mystery manifold' that exits the bottom of the engine tin and goes to both exhaust headers, this part I'm still working through. (IMG:style_emoticons/default/chair.gif) On the other side of the engine tin the standard 3.2 has a 'port' of sorts on one side of the fan shroud (currently capped,) a duct that terminates on an aux blower (still have the wiring harness on the motor), then duct work from the aux blower to the engine tin terminating just next to the distributor cap. There should be some form of flange in the tin that mates the upper and lower together. I know because the engine bay is not the 3.2's native land there will be'customization' (IMG:style_emoticons/default/sawzall-smiley.gif) (to be fair I don't like customization, that's how you get terms like Mississippi'd or 'mickey mouse'd' I hope to photograph the process here, and while advice is always appreciated, I -can- use the google search function too, so I'll be looking at everything else in the meantime. |
914forme |
Jan 17 2018, 03:16 PM
For future reference, you can also hook up a leaf blower to the ducts as the drop down from the heat defroster selector. And blast all the crap back towards the engine side, before you hook up the heat. This saves you from cleaning the interior. You then have to just hose off the engine compartment.
I need to remember to do that myself, before I get to far (IMG:style_emoticons/default/huh.gif) Enjoy the heat, glad it all worked out for you. |
burton73 |
Sep 22 2018, 04:25 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
For future reference, you can also hook up a leaf blower to the ducts as the drop down from the heat defroster selector. And blast all the crap back towards the engine side, before you hook up the heat. This saves you from cleaning the interior. You then have to just hose off the engine compartment. I need to remember to do that myself, before I get to far (IMG:style_emoticons/default/huh.gif) Enjoy the heat, glad it all worked out for you. Thanks for this great tip. Bob B |
worn |
Sep 22 2018, 07:55 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
For future reference, you can also hook up a leaf blower to the ducts as the drop down from the heat defroster selector. And blast all the crap back towards the engine side, before you hook up the heat. This saves you from cleaning the interior. You then have to just hose off the engine compartment. I need to remember to do that myself, before I get to far (IMG:style_emoticons/default/huh.gif) Enjoy the heat, glad it all worked out for you. Thanks for this great tip. Bob B But is he really saying you can use a leaf blower as a defroster fan? Fall is in the air and the squirrels are storing walnuts in my car. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:19 AM |
