smog pump delete 1976 2.0 cali car |
dax1969 |
Dec 14 2017, 07:08 AM
Member Group: Members Posts: 362 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Hi guys,
Tried the search option but can't find what I'm looking for. I know that the Cali 1976 914 2.0 has a smog pump/system to pass emission test. If such a system is not needed in your area, would you remove it or leave in place ? Will you gain more power without this system ? If you remove the pump should you only block of the lines with caps you can buy at AA or else or are there any other modifications needed ? Other exhaust ? thks yr advise krgds Dax |
VaccaRabite |
Dec 14 2017, 01:27 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Remove the belt, but also cap off the ports at the heads.
Backdate the exhaust. Will need earlier style heat exchangers and muffler. That way you are retaining heat, finding lost HP, and can still easily bring up back to 75/76 stock with only an afternoons work. Zach |
Lo-Fi Version | Time is now: 18th May 2024 - 11:14 AM |
